It is currently Tue Jul 16, 2024 9:26 pm
 Post subject: oops
PostPosted: Tue May 26, 2009 6:44 pm
i forgot to leave an empty spot between the pre amp tubes and the power tubes. will this be a problem? i could fix it at this point, i will just have to rewire the heaters between them.
PostPosted: Tue May 26, 2009 10:44 pm
:?: On my layout it shows the unused tube socket is on the extreme preamp end of the chassis closest to the side!
PostPosted: Wed May 27, 2009 7:13 am
If you left a space between the pre / power, even that should be OK.
PostPosted: Wed May 27, 2009 8:45 am
Stephen..
On the layout diagram I have the unused tube socket hole is at the far right on the drawing,in otherwords outboard of v1! Is this not correct?
Stew
PostPosted: Wed May 27, 2009 9:33 am
that is fine & correct.
PostPosted: Wed May 27, 2009 11:28 am
i guess i got the v6 chassis because i have 5 pre amp holes, 2 el84's plus the rectifier.
PostPosted: Wed May 27, 2009 11:53 am
well the V6 will have two large holes for the octal sockets (6v6s).
PostPosted: Wed May 27, 2009 2:01 pm
All 18 watt/TC chassis start out the same. Head chassis has 8 holes, combo has 7.
We punch out bigger holes for the TC & 6V6 & then plug unused holes. Plugs provided in kits too.
Users browsing this forum: No registered users and 49 guests
