It is currently Tue Jul 16, 2024 9:22 pm
PostPosted: Mon Jun 22, 2009 4:00 pm
Hi,
I'm building a combo plexi kit first build and i've done the heater wiring,
p/t wiring up to the standby switch onto can cap without the resistor.
Do you test before wiring the rest in and if so where oh it's 240 volts btw.
Another quick question on the shielded wire, do you run 2 wires on each
input jacks plus 1 on the gain pot, the only reason i ask is is there enough
cable in the kit.
Thanks for your help.
PostPosted: Mon Jun 22, 2009 9:12 pm
You can actually build the amp and test the PT AC lines with the rectifier tube removed. Its' a very good idea to test the AC is correct but connect all the AC lines so it's safe to measure.
There should be enough cable for 4 inputs & the gain. If not, we'll send over some more.
 Post subject: shielded cable for combo
PostPosted: Tue Jun 23, 2009 3:36 am
I don't think there is enough cable in a combo kit because when you face
the tmb side the opposite way it's further away from v1.
I was trying to measure it but that's how it seems to me.
Your advice would be useful, or have a measure up and let me know.
Thanks.
PostPosted: Thu Jun 25, 2009 11:38 am
I thought i wouldn't have enough myself... It ended up being the perfect amount, not a lot of room for error lol, and it made routing a little bit harder; but I made it.
PostPosted: Thu Jun 25, 2009 9:53 pm
:D
