It is currently Wed Dec 03, 2025 9:09 pm
 Post subject: Deluxe Finally Finished
PostPosted: Tue Jun 30, 2009 2:27 pm
Now that I'm done teaching for the summer, I have managed to finish my cabinet. The new OT made all well. After countless hours of research, I decided to put a W***r Vintage Series 12F150 25 watt speaker in it. Lots of tweed spank in there. Here's the final product. And yes, that's doubled burlap lacquered for the grill cloth.
PostPosted: Tue Jun 30, 2009 8:34 pm
Nice vintage look to go along with the Tweed Tone. Doubled burlap lacquered ?
PostPosted: Tue Jun 30, 2009 8:43 pm
Yeah Stephen, I bought some burlap for $1 a yard, folded it in half, stretched it over the baffle, and sprayed it with a few coats of clear lacquer to stiffen it up. I had posted a question on the tele forum about using burlap and a fellow posted some pictures of an amp he made using a burlap feed sack for grill cloth. It still had the seed company logo on it...looked pretty different.
PostPosted: Wed Jul 01, 2009 3:40 pm
Wouldn't burlap absorb the high frequencies...? :?
PostPosted: Wed Jul 01, 2009 8:01 pm
You'd know better than I would Phil. I'm just a teacher, not an engineer like yourself. Have you had experience with burlap before or just using logic in asking your question? Though probably not acoustically transparent, it sounds good and sparkly to me, but perhaps I'll take it off and see if it opens up a bit. There is quite a bit of space between the strands and I thought the lacquer would have helped it some too. I've read here where many think the Deluxe's bass is too flubby, but I'm liking mine as is. Sounds great with a strat.
PostPosted: Thu Jul 02, 2009 5:48 am
Duke wrote:
You'd know better than I would Phil. I'm just a teacher, not an engineer like yourself. Have you had experience with burlap before or just using logic in asking your question? There is quite a bit of space between the strands and I thought the lacquer would have helped it some too.
Being an engineer only means I make half-informed guesses about stuff I don't know. :lol: And theory is worthless without experimental evidence. I just thought that burlap fibres looked kind of fluffy to be acoustically transparent, but like you say the shellac probably deals with that.
Might be interesting to try some time, in the interests of the advancement of science - in other words just for fun. :)
It's probably fine with a Strat, but too flubby for an LP, especially when cranked. It's easy enough to fix though, with a couple or so small cap changes. But if you're only playing it fairly gently with a Strat, then there's no need to change anything. :D
PostPosted: Thu Jul 02, 2009 7:54 am
Most of the heavy Marshall grill cloths I put on is not transparent e.g Salt & Pepper, Cane, Bluesbreaker etc. Fender cloth is better at this than Marshall except maybe the recent Marshall basket weave
As for the burlap, it would be closer to the Marshall stuff if it was lacquered on both sides. One difference with the Marshall is the weave material has a very hard finish. The softer will absorb high end.
PostPosted: Thu Jul 02, 2009 9:19 am
Okay, now between the two of you I'm going to try a few things:
#1 I'll take the cloth off and try it without.
#2 I'll use a singe layer with a full can of lacquer
I'm used to my 18 watter, so that's my frame of reference. I may be surprised when the cloth comes off. I have also been playing an LP through it, but it likes my strat much better. Maybe that will change too.
PostPosted: Thu Jul 02, 2009 12:08 pm
Be careful you don't turn the burlap into a sheet of plexiglass with too much lacquer :lol:
You may end up with an iso-cab!
The cab came out great BTW. Nice job!!
Joe G
Some assembly required,
Brain sold separately...
PostPosted: Sun Jul 05, 2009 9:43 am
Most of the heavy Marshall grill cloths I put on is not transparent e.g Salt & Pepper, Cane, Bluesbreaker etc. Fender cloth is better at this than Marshall except maybe the recent Marshall basket weave.... One difference with the Marshall is the weave material has a very hard finish. The softer will absorb high end.
Yes, those Marshall cloths don't look ideal, but at least they're a good bit thinner than burlap, and like you say they have a hard finish. My old Marshall Mercury combo, that I built an 18W Lite inside of, has a Marshall checkerboard grill cloth material that seems to be woven from fine plastic-coated wire. I think that material is acoustically completely transparent.
