It is currently Thu Jul 18, 2024 9:41 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Sat Sep 12, 2009 1:07 pm
I finally found time to install two 9.1V, 5W zener diodes in the B+ line (at the standby switch), and that successfully reduced my B+ voltage from its original 390V to 362. My EL84 pin 7 (plate) voltages are now a safer 345 and 347V (down from 370V). This enables me to run NOS EL84s without fear of prematurely burning them out. The amp seems to sound a bit richer as well.
Many thanks to Zaphod and Coco especially for helpful guidance in this regard. On to some playing!
Jim
PostPosted: Sat Sep 12, 2009 4:07 pm
HarmonyoftheSpheres wrote:
.. and that successfully reduced my B+ voltage from its original 390V to 362.
Boy, that was high. Typical TC-15 is around 350 with our PT. Is your mains high too?
PostPosted: Sat Sep 12, 2009 5:19 pm
My mains voltage is 123V. Seems high to me, but these days most USA voltage is close to that, I've read. My voltages from the Trinity PT are 310V (at pins 4 and 6 of the rectifier), which is about 20V higher than what the TC-15 schematic shows as typical. Maybe Heyboer wound me a hot one!
I haven't tried a NOS 5AR4 (don't have one yet) to see if it will reduce the B+ voltage a bit further. I'm running a JJ now. But my present 345/347V at the power tube plates should be ok as is.
PostPosted: Sat Sep 12, 2009 11:10 pm
Yes, that's pretty good. And don't forget that for the true anode voltage you need to subtract the cathode voltage, which will take it down to somewhere around 333-335V.
