Anytime you hit a joint & it snaps, crackles or pops, it's a good be a cold joint so reflow one at a time & see.
Thanks Coco. I'm going to re-flow the ground connection at the input jack first and then work through all the other solder joints as needed. One thing i failed to mention was that v1 is also microphonic. The tubes I swapped in were Mullard re-issues and Tung-Sols, which were not microphonic in other positions. I don't relish the idea of re-flowing the socket joints since they are so close together and difficult to get to, but I'll re-flow those as well starting with the cathode pin.
On another note, I really like the Tung-Sols in my amp. I don't find them overly bright at all. JJ's sounded very shrill to me especially in V1. What I have in the amp now are TS's in V1 and V2 and JJ ECC803s in V3. I just have not found a spot I like for the Mullard. I might try the Mullard in V3 and the JJ in V2 to see what that is like. All that being said, I'm reading more and more about cathode follower failures with most new stock tubes.
What does that actually sound like? My amp has been a bit more saggy then I prefer lately which could be related to the other issues. I'm just curious about what a tube failing in the CF position actually sounds like.
PS
Looks like there are to Joe G.'s on this board so to avoid confusion I'll start tagging with Jersey Joe
![Cool 8)](./images/smilies/icon_cool.gif)
