It is currently Fri Jan 30, 2026 2:57 pm
 Post subject: PT question
PostPosted: Wed Jan 13, 2010 5:12 pm
OK, to wire up the PT for 120V it says in the instructions:
1. Connect black/white to black/red and black blue to black
Does this just mean twist the leads together and solder?
2. Connect mains to Black/red and Black.
So does this mean connect the twisted leads from #1 to mains?
Which end goes to the power cord and which end goes to the power switch?
PostPosted: Wed Jan 13, 2010 8:47 pm
That one had me thinking too!
Black/red and black/white are soldered together on the one side (the other side is coming off the fuse which has the black Line hot) of the on/off switch.
Line in white and black/black blue from PT get soldered together.
hornbyisland
PostPosted: Wed Jan 13, 2010 9:04 pm
OK, I get it. Thanks!
PostPosted: Wed Jan 13, 2010 9:21 pm
Don't forget to insulate/wrap or isolate the white - black/black blue after soldering together.
hornbyisland
PostPosted: Wed Jan 13, 2010 11:46 pm
Sorry, this post tried to explain a bit more.. viewtopic.php?t=1873
I guess this is still not clear enough in the Manual?
PostPosted: Thu Jan 14, 2010 9:38 pm
Its not bad in the manual, I just wanted to be sure, I've never wired one up that's dual voltage. It would have been easier if there was a picture, maybe I'll post one when I have it hooked up.
PostPosted: Thu Jan 14, 2010 10:14 pm
Thanks. I can understand your concern.
