It is currently Wed Jul 17, 2024 1:28 am
 Post subject: Marshall knobs
PostPosted: Tue Jan 19, 2010 10:34 pm
The Marshall knobs we have been shipping with the kits have become quite tight. The knob manufacturer makes the Marshall knobs with a very tight tolerance so, you might experience quite a bit of friction installing them on the 1/4" diameter pot shaft. Don't force it. Back out the set screw and chase the hole with a standard 1/4" drill bit. The wobble in the drill will ream it out just enough that any standard 1/4" shaft pot will fit fine. It just takes a second to ream it out. Sorry for the extra work involved. For this reason, we'll be changing suppliers from original Marshall to ones with a brass bushing.
 Post subject: I know
PostPosted: Sat Jan 23, 2010 11:11 pm
Can you send me a set of the new ones. I f'd mine up trying to fix them when I finished my kit. There is no way they were going on those shafts.
 Post subject: Re: Marshall knobs
PostPosted: Sun Dec 12, 2010 1:31 am
This thread is a bit old. Has the change yet occured?
PostPosted: Sun Dec 12, 2010 12:54 pm
Yes, 200 knobs ago!! :wink:
PostPosted: Mon Dec 27, 2010 2:10 am
here we can remove the knobs from Marshall amplifiers is similar to that of any amplifier or guitar. the set of screw is present if a small hole or screw head is visible.
Tips & Warnings:-
1.here we should Always use gentle pressure when pulling friction knobs.
2. we need to Avoid full set-screw removal, otherwise it will be be easily misplaced.3.33.
3.we Don't over-tighten set-screws,otherwise it will crack.
[url=http://www.usc.co.uk/Jeans/10100,default,sc.html?prefn1= brand&prefv1=Diesel&fix]mens diesel jeans[/url]
Users browsing this forum: Google [Bot] and 18 guests
