It is currently Tue Dec 02, 2025 6:19 am
 Post subject: Plexi Pics
PostPosted: Mon Jan 25, 2010 8:17 pm
I finished the build and though I have a couple of minor things to work out, I am very pleased with the results :D I have seen the outstanding job y'all have done with your builds so I am a bit nervous about putting mine up here. But I am going to, so if you see something I need to do differently please speak up.
I was out of town over the Christmas holidays but this was what I came home to! The 4 smaller boxes are tubes.
The parts were packaged very well and after going through the master list and accounting for everything the build began. First the turret board. I forgot to take shots of the backside:
PostPosted: Mon Jan 25, 2010 8:25 pm
The rectifier, mains, and fuse:
V1, V2 & V3
V4 & V5
PostPosted: Mon Jan 25, 2010 8:29 pm
The impedance switch:
The output jacks:
The boost switch:
PostPosted: Tue Jan 26, 2010 7:28 pm
Then the pots:
Input jacks:
PostPosted: Tue Jan 26, 2010 7:33 pm
Completed except for tying things together:
PostPosted: Wed Jan 27, 2010 7:00 am
I'm a nubie myself, however you might want to check the resistor on v2, should be a 100K carbon metal resitor looks like just a carbon resistor (check with stephen).
PostPosted: Wed Jan 27, 2010 1:10 pm
Looks good, nice build.
You might consider touching up a few joints (you have a few that look like "cold" joints) and adding a bit more solder to the turrets.
PostPosted: Wed Jan 27, 2010 2:15 pm
Carbon film or Metal is an option here. You might have received both or either, but carbon comp is my preferred one.
PostPosted: Wed Jan 27, 2010 3:39 pm
Thanks for the compliment :D On some of the turrets, especially the ones with only one connection, the solder would just flow down into the hole so I stopped. The connections seem solid but I will go over them again just to be sure. Thanks for the advice :thumbsup:
Thanks for pointing out the possible cold joints. Things really show up better in the pictures, good and bad.
I received both metal and carbon film. I actually put the carbon film in there by accident and then decided I would leave it there and try it and see how it did.
