It is currently Sat Dec 13, 2025 5:50 pm
PostPosted: Mon Feb 01, 2010 10:52 pm
So I had a ceramic socket in V2 and was swapping out tubes the top and bottom of the socket came apart. Replaced socket with a micalex socket and have a problem. The volume pot on ch. 1 and the gain pot on ch.2 are acting like on/off switches. Ok amount of volume coming from ch1 but very little of anything from ch2. It sounds like on pot is shorting the other.
I did inadvertently switch how I wired the 100k resistor.
I went from pin 1 to pin 7 and jumpered pin 1 to pin 6. I also went from pin 6 to R21 and C11-12 as per the schematic. Could not having the resistor directly across both plates be causing the problem?
The only other change I made was switching out C1 to .022uF. I re-flowed everything that was changed and the joints look good. Reflowed grounds as well. What's going on?
Thanks as always,
Jersey Joe
PostPosted: Mon Feb 01, 2010 11:03 pm
Not exactly sure what you've done but why don't you wire the tube the way the schematic says? Pin 1 to 7, 1 to 6??? If you are trying to reverse which triode is the driver and which is the cathode follower then you need to swap all 3 connections on both triodes.
Stew
PostPosted: Tue Feb 02, 2010 10:35 am
That resistor has to go across the plates as per the layout.
PostPosted: Tue Feb 02, 2010 9:56 pm
Coco, I see now how both channels share the first triode of V2. I made a silly mistake. :shock: I really could benefit from that amp seminar :)
Someday I'll understand all this. Time is my worst enemy.
Current reading: http://www.freewebs.com/valvewizard1/dccf.htm
