Scott_F wrote:
So, Stephen, riddle me this?
What bolt size goes into the caged nut on your chassis? It's not the "standard" Marshall sized one that I normally see. I was messing with mine last night and had was pulling my hair. I ended up putting in some standard sized caged nuts and went with the bolts I had.
The size is 10-32. That's a number 10 screw with 32 threads per inch.
That is inches not mm. Pretty common in North America but not so common across the pond. This is for the gold combo chassis not the head chassis with the pressed in thread. Hope that helps.
Bruce (a fellow Canuck)
