It is currently Tue Jul 16, 2024 11:37 pm
PostPosted: Mon Feb 01, 2010 10:19 pm
I was playing with a band & the trinity 18watt sIII starts having the volume go up & down. Next thing the power & pre amp tubes go dark. A spare set of power tubes didn't remedy it and the original tubes test good.
Any thoughts before I start taking voltage readings?
PostPosted: Mon Feb 01, 2010 10:48 pm
Can you see a lit filament on the recto tube?
STEW
PostPosted: Tue Feb 02, 2010 10:09 am
STEW
Yes, the filament on the recto is bright orange.
PostPosted: Tue Feb 02, 2010 10:33 am
Check filament voltages on power & preamp tubes. Sounds like a break there at the first tube.
PostPosted: Wed Feb 03, 2010 9:35 pm
here's the recto
p1 307
p3 117
p4 6.6
p5 9.26
p7 307
I see p4 & 5 look off should I try a different recto tube?
PostPosted: Wed Feb 03, 2010 9:43 pm
There's no reading on P3 on the power tubes. the other pins are normal.
hmmmmm any ideas?
PostPosted: Wed Feb 03, 2010 11:41 pm
Pin 4 & 5 of recto should be filament voltage. 6.3 VAC. There should also be 6.3 VAC on all the filaments of the rest of the tubes.
PostPosted: Thu Feb 04, 2010 11:41 am
So the heaters are all measuring good. Could the recto tube be dead? I'll grab another after work and give it a try.
PostPosted: Fri Feb 05, 2010 10:42 am
A quick check of ypur B+ will answer that question.
Stew
PostPosted: Mon Feb 08, 2010 11:04 am
the plot thickens....
Just tested the power tubes and the rectifier tube with a tube tester. They test good & didn't have any shorts.
now for the funny voltages (all tubes in, both switches flipped on)
recto p1 313
p3 400
p4 4.9
p5 9
p7 314
Filter cap B+ 406
Power tube closest to recto
p2 400
p3 nothing??
P4&5 measure 6.9 across the heaters (Gulp)
P7 408
P9 408
A new rectifier tube has no change on the readings.
Could the 200uf cap failed? I hope it's not the transformer... I only have about 100 hours on the amp.
Any tips on what to check next?
PostPosted: Tue Feb 09, 2010 9:32 pm
How about the filter caps? is 400v too high?
PostPosted: Wed Feb 10, 2010 2:07 pm
Pull out the rectifier and measure all the AC voltages. Pull out the other tubes and measure the heater vltages.
If all is well, repeat the start-up procedure in the manual.
PostPosted: Tue Feb 16, 2010 10:17 pm
Thanks for the guidance.
OK - I took some time away from this to clear my head. I'm ready to tackle this beast & get it back to fighting weight.
I got my manual out & took some measurements.
Without any tubes, all the ac looks OK.
rectifier socket pins 1 & 7 measure just over 304. Pin 3 shouldn't matter at this point as stand by is off. Pin 4 is 5v and p5 is 9.4v
With only a rectifier tube in, stand by is still off pins 1 & 7 measure just over 304. Pin 3 measures 110, Pin 4 is jumping around 9v and p5 is jumping around 10v
flip stand by again no change in pins 1 & 7. Pin 4 is 4.4v and p5 is 8.3v. Pin 3 is now measuring the same thing as the B+ at the filter cap, 393.
Is this all normal?
PostPosted: Wed Feb 17, 2010 11:11 pm
On the rectifier, between pin 4 & 5 there ahould be 6.3V AC. Is there?
You are saying Pin 4 is 5v and p5 is 9.4v.
PostPosted: Thu Feb 18, 2010 9:22 pm
I was not measuring across 4&5....
With out the tube in it measures 6.8v
tube, it's 6.6v
is this troubling?
& get this, after putting the tube in, the power tubes light up. So I plug in the SG and it works.
I'm going play through it it for a few hours.
PostPosted: Fri Feb 19, 2010 10:14 am
6.6V or 6.8V is fine. It just needs to be within +-10% of 6.3V.
PostPosted: Fri Feb 19, 2010 11:01 am
Thanks zaphod.
I logged 3 hours on the beast running 1/2 way open. So far I'm cautiously optimistic.
It bugs me that I never discovered the issue.
Users browsing this forum: No registered users and 57 guests
