Experienced |
Joined: Sun Jan 07, 2007 6:40 pm Posts: 423 Location: Northern Ontario, CANADA
My sIII (my first build and therefore a little sloppy) also had a squeal when the gain was up and boost on... until I moved some wiring around, and shortened some of the runs.
You can try using a chopstick while the amp is powered up to move wiring a little and sometimes just a small change in positiion makes a big difference. My Triwatt also had the same issue, which iwas also solved by slioghtly moving some wires and using zip ties to hold them where the squeal was gone.
AJC
