It is currently Tue Jul 16, 2024 11:34 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
PostPosted: Sat Mar 06, 2010 11:44 am
when i first started the amp i had no power at all, very low distorted sound with vol all up. finally found i had left out the output coupling caps. after fixing that the amp seems verry loud. i cant seem to get a good tone at low volumes. the gain is lose and fizzy.
PostPosted: Sat Mar 06, 2010 11:53 am
Can you post your voltages and compare them to the layout.
PostPosted: Sat Mar 06, 2010 2:04 pm
refering to the s111 plexi layout where voltages are indicated on the board next to the eyelets, from left to right my voltages are 13, 333, 208, 219, 55, 80, 57, 189, 123, 1.24, 100.7, 101.5, .72, .71, measured to ground. voltage across the 150 ohm cathode resistor is 13.17
PostPosted: Sun Mar 07, 2010 12:43 pm
it looks like im at 14 watts dissipation. do i need to go up to a 180 cathode resistor?
PostPosted: Sun Mar 07, 2010 1:19 pm
I wouldn't concern myself with the o/p tube bias until you get those preamp voltages in line. That may or maynot change the plate voltages on the o/p tubes and hense the disapation. Is that 2.2K in the center of the board correct?
Stew
PostPosted: Sun Mar 07, 2010 1:20 pm
No, it's fine. Generally the volatages seem low. The cathodes on V1 should be close to 1V, not .7V
PostPosted: Sun Mar 07, 2010 4:07 pm
just checked that 2.2k and it reads 22k, the colors are red red black red. so 2.2k and 2k2 are 2200 ohms?
PostPosted: Sun Mar 07, 2010 8:43 pm
Yes, 2.2K = 2K2 .
22K = not correct!
PostPosted: Sun Mar 07, 2010 9:46 pm
does the layout show 22k or is the decimal not visible? if you could change the layout to show 2k2 that would prevent this from happening again. i used the layout to build the entire amp.
PostPosted: Sun Mar 07, 2010 10:27 pm
Fair enough. It is 2200 ohms, 2W, not 22K
All layouts have been updated, and other notations checked.
PostPosted: Mon Mar 08, 2010 12:16 pm
ok heres new voltages, 13, 328, 196, 205, 51.5, 75.5, 53.6, 256, 168, 1.6, 138, 139, .95, .95. looks like 43ma at 13.5 watts. i still think i should increase the cathode resistor to 180 or probably higher. isnt 43ma way to much for el84's?
PostPosted: Wed Mar 10, 2010 3:52 pm
When doing the dissipation calculation did you remember to subtract tha cathode voltage from the anode voltage? Also did you subtract the screen current from the cathode current?
PostPosted: Wed Mar 10, 2010 4:50 pm
heres what i did,
13/150=.0866/2=.043, 328-13=315x.043=13.5W
PostPosted: Wed Mar 10, 2010 5:39 pm
this time from the pins
v4 =348 plate pin 7, 335 pin 9
v5=345.5 pin 7, 335 pin 9
voltage across the cathode resistor is 13
voltage across the 100r is .84 wich = .0084, do i divide that in half for two tubes? now
343-13=335, 335x.043-.0042=13
PostPosted: Wed Mar 10, 2010 7:41 pm
OK, that all looks correct. 13W really is too high. Looks like you may need to use a 180 ohm cathode resistor.
Funny I was talking to some guy on 18watt.com about the exact same subject. :wink: :lol:
PostPosted: Wed Mar 10, 2010 7:48 pm
no way, really?
PostPosted: Wed Mar 10, 2010 8:48 pm
Considering you used 150 ohms per spec, why would this be dissipating so much in this case? We have used 120 in the past. :?
heres another thought, i got the tubes from lv i think. the box have a sticker that reads 22.5/5.05. are these tubes to hot for this amp?
PostPosted: Fri Mar 12, 2010 2:44 pm
No idea. Probably LV should be able to advise you.
Another thing, IMO that shared 100 ohm screen resistor (from the classic 18W design) is also too low IMO. I suggest swapping a 1k in its place, and then measuring again.
PostPosted: Fri Mar 12, 2010 3:23 pm
Is it possible the 150 ohm is NOT 150 ohms? Please measure it.
Users browsing this forum: No registered users and 51 guests
