FYI this same question got asked on 18watt.com and here is what I said.
Local_Lad wrote:
V2- pin1 149
pin3 0.94
pin6 265
pin8 150
If pin 6, which is directly connected to the preamp's positive rail, is at 265V, this means the preamp rail is at 265V. V2a has an 820 ohm cathode resistor, according to the schematic on Trinity's site. So 149V on V2a's anode (pin 1) looks around what I would expect with that value of cathode resistor. 180V actually sounds on the high side to me. You also get some variation between tubes, even apparently identical ones. Since V2b is a cathode follower, you get almost exactly the same voltage on its cathode as on its grid which is directly connected to V2a's anode. So that all looks good. What really matters is most is that the amp sounds good to you.
HTH
