It is currently Tue Apr 08, 2025 8:03 am
 Post subject: 415 VDC on pin 1 of v1
PostPosted: Sat Oct 16, 2010 2:48 pm
I just finished the build. 313 vac on the pins of the 5ar4, so I put the rectifier in. Measured pin 1 of v1 and it was 415 vdc. Pins 7 on both v4 and v5 are both 430 vdc. The only tube in the amp is the 5ar4.
What could I have missed?
Jon
PostPosted: Sat Oct 16, 2010 4:06 pm
Until you have the power tubes plugged in and actually running (ie not on standby), you will get real high voltages like that.
PostPosted: Sat Oct 16, 2010 6:59 pm
Got it. Problem solved. Thanks Phil!
