It is currently Tue Aug 11, 2026 7:54 pm
PostPosted: Wed Jan 05, 2011 6:54 pm
Apparently Dr.Z offers this mod on some of their amps including their 18? There's a foot switch that bypasses the E.Q. and gives extra gain!..? Anyone done this or heard the results of this mod?
PostPosted: Wed Jan 05, 2011 7:06 pm
My Allen Old Flame does something similar to this via a pot called the Raw knob.
Bypassing the tone stack seems to incrementally beef up the gain, most noticably in the mids. Sort of takes a BF type amp and adds a Tweed vibe for a while (low knob settings). Higher settings are more all out grind.
I'm pretty sure there are a few current production amps that do this very thing to add a pseudo second "channel" tone.
PostPosted: Wed Jan 05, 2011 8:49 pm
I just did this mod on a Tramp I built. I added a footswitch to turn the boost on and off. I have the boost set up a fixed resistor but you can make the amount of boost variable by using a rheostat. I'll post a pic later if you want.
Btw often referred to as the "raw mod".
PostPosted: Wed Jan 05, 2011 11:12 pm
Yeah, there is a drop in gain thru the tone stack so bypassing will jack it up a bit. I'd like to hear it!
PostPosted: Thu Jan 06, 2011 2:45 pm
Hmm, I still have an unused push pull pot switch on the gain knob of my TMB channel, maybe I should rig this up.
PostPosted: Thu Jan 06, 2011 3:10 pm
Here is how I did it on a Tramp I just built. I used a 680K resistor....
Very easy to implement. Could be done with switch too.
No cable plugged in no boost, amp is stock. Plug in a cable and you can toggle between boost and stock.
PostPosted: Thu Jan 06, 2011 3:27 pm
would that be R13 on the Tramp schematic? Would you wie it the same way on the 18 tone stack?
PostPosted: Thu Jan 06, 2011 3:48 pm
Hey Stoo, ya it would be R13 on the Tramp schem. Disconnect that guy and run it to the jack/switch.
This boost can be implemented on any amp with the classic Fender/Marshall tonestack (so a ton of amps). It can be implemented in various other ways on others tonestacks and areas of amps but that's something else...
I'm looking at the sIII schem here
viewtopic.php?f=12&t=689
See the mid pot VR6. Disconnect its connection to ground (lug 3). Run that lug 1 to the jack/switch instead of ground. Then implement as shown above.
PostPosted: Thu Jan 06, 2011 4:57 pm
So instead of open circuit you're using a fixed resistor, how does it affect the tone pots on your build?
PostPosted: Thu Jan 06, 2011 5:49 pm
You can use an open circuit but the increase in gain/boost is nuts.
Tone stack is rendered useless, treble pot still has a little affect. Your bypassing the TS...
PostPosted: Thu Jan 06, 2011 9:33 pm
Okay cool. I think I'll get some alligator clips and try out some mods to see what I want to do with that extra switch I left for myself.
PostPosted: Fri Jan 07, 2011 12:26 pm
:D Keep us informed OK FF!?
PostPosted: Fri Jan 07, 2011 9:02 pm
Sure, I know everyone thought I was insane when I mentioned it in my thread but I kind of want to try silicon clipping after the first gain stage of the TMB channel too.
Anyone have the gain of that stage calculated? I just did some rough estimations that the signal would be around 12V after this stage. I'll have to look into it in more detail.
PostPosted: Fri Jan 07, 2011 9:17 pm
^that sounds high. What was your numerical gain value you calculated and your estimated input signal strength?
PostPosted: Sat Jan 08, 2011 2:43 pm
Estimating gain of 44, input signal ~300mV.
PostPosted: Tue Jan 11, 2011 3:57 pm
I heard this mod on Sunday and it is worth trying it out. Almost like a boost switch. Quite cool if you dont mind the reduced Tone controls.
PostPosted: Tue Jan 11, 2011 4:39 pm
What sort of amp Stephen?
PostPosted: Tue Jan 11, 2011 5:11 pm
Cool, I'll definitely try it. I've done this on my champ and it's pretty useful.
PostPosted: Tue Jan 11, 2011 9:18 pm
champ has no tone control. what did you do?
PostPosted: Wed Jan 12, 2011 3:13 pm
Vibro Champ sorry. Bypassing the tone-stack turns it into a regular Champ. I also added a dummy load and line-out to drive the front of the 18W for fuzz or tremolo. It gets pretty hot when I crank it into the dummy load. I used 2 5W 10ohm resistors in parallel, I think I might add another one for a 3.33ohm load (15W), the 4ohm output on the amp might be happier with that.
