It is currently Sat Jan 31, 2026 4:44 am
PostPosted: Sun Mar 27, 2011 5:34 pm
I just completed a plexi kit and the normal channel works great but there is no sound from the tmb channel. All voltages check out. I initially found a problem where I had connected one of the signal inputs to v1a (pin 2) to the center lug of the termial strip thus grounding it. I corrected that problem but still no sound. Also with both the gain and volume at high settings a loud squeal develops at high treble settings. Please advise with any suggestions.
PostPosted: Thu Mar 31, 2011 12:35 pm
Have you resolved your issue yet? You can start by re-tracing/re-checking every connection marking them on the layout as you go.
Les
PostPosted: Thu Mar 31, 2011 1:07 pm
Assuming you've got the amp open on the bench..
With the TMB Master volume turned up half way..do you hear a "pop" when you touch a voltmeter lead to pin 2 or pin 7 of V2? If so then the problem is with V1a or the volume(gain) control. If not then the tone stack/master vol. area is suspect. This assuming also, that you've changed tubes ect.
