Goran wrote:
I said speakers, as I think about making a 2x12 Combo.. the second speaker will/should probably be a Alnico.. Probably, for the beginning one speaker is enough
Don't have an Alnico as your only speaker. Most alnico speakers have quite a bright sound, and EL84s are also naturally bright sounding tubes. So the end result can be ice-picky. In combination with something darker, like a G12H-30, it's another matter.
Goran wrote:
I wanted this one to be 16 Ohms, as I read quite a lot that those sound best..
I don't see any evidence for that. You will get slightly more of the very high end frequencies coming through the OT on the 16 ohm winding, but it's a matter of personal taste whether that is "better" or not.
Goran wrote:
the Celestion G12H30 70th anniversary is not bad at all. I like the sound. I must also say that I liked the Jensen P12n. But would a speaker rated 50 W like the Jensen and a Celestion g12H rated 30 Watt be too much for a 18 Watt amp? I mean, wouldn't a Celestion alnico blue with 15 Watt be a better companion to a G12H 30 Watt? Aren't the 50 Watt to much?
It's not too high for the amp. Just you will get less speaker distortion with high wattage rated speakers.
Goran wrote:
And how different would a 1970ies Celestion G12H30 sound in comparison to this 70th anniversary model or the UK-made model? Any differences?
An older speaker will sound mellower. Also you need to check whether a vintage G12H-30 has the 75Hz "Lead" cone or the 55Hz "Bass" cone. The 55Hz version is darker and mellower at the high end, which I personally prefer. The Anniversary G12H-30 has a 75Hz cone, while the Made in England G12H-30 "Heritage" version has the 55Hz cone.
Goran wrote:
What are the combinations people have used in the past that just have been proven to be always good? I have read that an Alnico Blue and a G12H30 make a good 2x12. Also, is it true that a Celestion Vintage 30 and a G12H30 make a good combination?
Yes, those are both good combinations, especially if the G12H-30 has a 55Hz cone. With th V30 it will be more punchy.
Goran wrote:
Are there other combinations that just can't go wrong? How about a Celestion G12H30 and a Jensen P12N? It seems to me, that a darker and brighter speaker are always paired in such a 2x12 combination. How would a Tone Tubby Alnico work with a Celestion G12H30 (70th anniversary or UK-made)?
Yes, that would sound pretty nice! Also if you can get Eminence speakers in Croatia, you might like to consider the Wizard as an alternative for the G12H-30, the Red Fang as an alternative for the Alnico Blue and the Guvnor as an alternative for the V30. Also be aware that these are all a bit louder than their Celestion equivalents.
plexiblues wrote:
Then i bought a couple of old 70's g12h's and they sound fantastic to me at home.
I tried the pair of them at a gig in seperate 1x12 combo cabs in the normal channel
and they didn't cut through, i was gutted btw.
You should have put them into a closed back 2X12 cab. Then you would have really got lots of volume level from them. Or a "detuned" 4X12 cab - ie a 4X12 with two of the speaker holes left empty, so the sound from the back of the speaker cones comes out the front of the cab and adds t the overall volume level. If that's not loud enough for you, then your hearing is going to get like Pete Townshend's.
