It is currently Mon May 19, 2025 10:13 am
 Post subject: switching the vol cap
PostPosted: Fri Mar 25, 2005 8:37 pm
Hey, I've got a few extra switches lying around that are just begging to be used, so I was thinking that one of the easiest little things I could do to my lightning is put the volume cap on a switch so I can take it out of the circuit ...
would there be any problem in doing this? I can't imagine it would or could cause any problems.. .but ... I'm new with actually tweaking circuits so I want to make sure! :)
thanks!
//daniel
PostPosted: Fri Mar 25, 2005 9:50 pm
There is absolutely no problem with doing that at all, but I would recommend using a push-pull pot for the bright switch.
--s2
www.s2amps.com
www.category5amps.com
