It is currently Wed Apr 02, 2025 1:01 am
 Post subject: New 18 Watt build
PostPosted: Sat Jul 09, 2011 1:48 pm
Hi... my first post and my first 18 Watt build
I have a problem that there is no sound unless you crank the 2nd volume to max, and the input sound can be heard ( very very faint) .. along with some buzzing. If you crank the gain to max it will go quiet. On the RH channel, the sound cannot be heard. It's the same for both the 6V6 and the EL84 tubes... I also get no sound when I switch the POWER boost switch, but I can see the voltage change on tube V2, when switched.
I checked all my voltages, retraced every connection, component values and Cap orientation and checked al the connections for continuity.
The only problem I found was that resistor R11, which is part of the tone/volume circuit is a 470 K instead of a 47 K (oops on the color banding identity) I don't have the correct resistor, so I can't change it...
I wonder if that could cause the problem.
I am also not totally clear on the input jack coax wiring, so that may be wrong? It sounds like a crossed wire to me..
advice?
 Post subject: Re: New 18 Watt build
PostPosted: Sat Jul 09, 2011 2:43 pm
Which channel is not working?
Post all the voltages & compare them to the layout and see if there is any big differences?
If all the voltages are right, then carefully touch the grid of the premap tube with a conductive small screwdriver and see if you get a pop. Grids are pins 2 & 7 on the 12AX7 and 2 on the EL84 and 5 on the 6V6.
Check that the tube selector switch is wired correctly as well.
470K in the tone circuit would take most of the bass out (below 1K)and it would make the tone sound pretty odd.
Was the 47K resistor missing? You can sub 56K - 33K carbon film.
PostPosted: Sat Jul 09, 2011 4:43 pm
The channel that (barely) works is the LH channel no response at all from the RH
yes the 47 K resistor was missing
the voltages are below:
V1 - 12AX7
Pin Volts
1 134
3 .8
6 132
8 .8
V2 - 12AX7
Pin Volts
1 230
3 2.03
6 230
8 1 229
V3 (PI) - 12AX7
Pin Volts
1 161
2 40
3 62
6 182
7 46
8 62
V4 - EL84
Pin Volts
3 18
7 284
9 215
V5 - EL84
Pin Volts
3 44
7 284
9 214
PostPosted: Sat Jul 09, 2011 5:54 pm
when I touch the pins on the tubes they pop a little bit a lot on pin 7 of V3
as far as i can see the selector switch is wired correctly.. it pops when you switch
does it matter if I have one ecc83S ( from JJ) in the preamp?
PostPosted: Sat Jul 09, 2011 7:00 pm
Success!!!!
I had missed connecting the wire from the RH tone control to the turret board. I was concentrating on the tube side of the amp ...
It sounds good!!.. The 6V6 are a LOT quieter than the EL 84's.
The LH channel still doesn't work, but know I know the pre-amp works I can concentrate on that side..
PostPosted: Sat Jul 09, 2011 7:01 pm
Something may still be wrong. Recheck the voltages as they were/ are out of whack.
>>> Specially Pin 3 on the EL84s is way out. It sohuld be 12V. Check your bias resistor value. The B + is too low as well, is should be around 340.
Get these sorted out.
If you have a VRM, make sure it is at max for these readings.
PostPosted: Sat Jul 09, 2011 7:03 pm
martysh wrote:
Success!!!!
Good news but check the voltages again. The v6 are quieter, but I wouldnt say a lot, about 3 db. There is a tweak for these if you want to drive them harder. But get it all going first.
PostPosted: Sun Jul 10, 2011 8:02 am
B+ is 344
The VRU works well and at full volume it only seems to rob 2 or 3 volts or so..
here are the rest of the voltages:
V1 - 12AX7
Pin Volts
1 136
3 .88
6 138
8 .9
V2 - 12AX7
Pin Volts
1 184
3 1.69 no boost , boost on 2.04
6 244
8 242
V3 (PI) - 12AX7
Pin Volts
1 185
2 47 ( big time snap when i use the meter)
3 72
6 196
7 50 (goes silentwhen I use the meter)
8 72
V4 - EL84
Pin Volts
3 12
7 338
9 325
V5 - EL84
Pin Volts
3 11.77
7 332
9 320
PostPosted: Sun Jul 10, 2011 9:30 am
That's better. Check the power supply chain to V1, the voltages seem a little low, especially the cathodes:
V1 - 12AX7
Pin Volts
3 .88
8 .9
The VRM is working according to design too. I'll send out a 47K resistor.
PostPosted: Sun Jul 10, 2011 10:52 am
the wire from pin 3 and 9 are short and terminate in the turret board.. no problems with the wire.
I am now at a loss...
ther is 6.0 vac on pins 4 5 to 9
PostPosted: Sun Jul 10, 2011 2:12 pm
What is your mains voltage? The heaters voltages should be closer to 6.3VAC.
It's just that ideally you want the cathodes there to be closer to 1V. Obviously it works.
PostPosted: Sun Jul 10, 2011 7:12 pm
The mains voltage is 114 VAC.
I did go to another plug that the incoming was 113 volts, and the 6 volt to the tubes was 5.9. I can't believe the transformer is so sensitive.
Well.. I knocked the EZ81 tube and broke the Glass nipple from the end, so it is no longer a vacuum tube...
I guess I need to wait until a new one arrives.
I guess I will resume trouble shooting this amp then...
PostPosted: Tue Aug 02, 2011 9:45 pm
O.K. several weeks later, I finally got back to this beast.
Well it turns out resistor R8 was 1k instead of 100K .. ( on the gain pot, input to pin 7 of V2) I must be getting color blind as I age.. I changed it out for a 100K Takman brand (nice pink color) resistor.
It doesn't really make sense to me that a 1 K resistor would cause this problem?
I first tried the amp with no resistor (maximum gain) but it was too much.
I also noted that this TMB channel is not as loud as the sIII channel..
I played it for a while through my Warehouse 1 X 12" Green Beret speaker. Sounds O.K., but I think I need to tune the sound.
thanks
Marty
PostPosted: Wed Aug 03, 2011 9:05 pm
Marty, It's math: 6/120V = 5% voltage reduction over spec. So all the AC will be 5% less so 6.3 V X .95= 5.985V
R8 dumps the gain a bit. 1K would be more gain, 100K less.
How do you want "to tune the sound."
PostPosted: Thu Aug 04, 2011 10:50 pm
Well I played this amp for several hours tonight, and I'm not sure I need to do anything yet to change the 'sound'. I do notice that the sIII channel is about 1/4 the volume as the 'normal' channel.. when you chain them together the sound is great . Lots of flexibilty. I like the 6v6/EL87 switch It really changes the character.
here are some pics of the finished amp.. I did the head cabinet as my take on a 'modern' Marshall 18 Watt.. You can see through the cabinet grill and see the tubes, as per the new Marshall head cabinets, but the size of the cabinet is the 'small' cabinet size. Russian birch ply, Marshall elephant 'tolex', and original Marshall grill cloth from the U.K.
The speaker cabinet is the same dimensions as a Marshal 1960 1X12 cabinet and has a 1 X 12 Warehouse Green beret speaker ( supposedly like a Celestion green back).
I added the VRU on the front panel in place of the standby switch, called it level, and added a 3 position off/on/on toggle, for standby (idle) and on. I had a new faceplate made by MOJOTONE. I also used a square 'Marshall like' power indicator, and a Marshall power switch bezel. Interestingly they are almost the same as the MG toggle switch bezels. I guess it's a 60's British thing.
PostPosted: Fri Aug 05, 2011 8:46 am
Looks good. The two channels should be very close to the same volume level. So there's is still something not going on there.
PostPosted: Fri Aug 05, 2011 9:29 pm
I thought something wasn't right.. When I back the gain to 5 or so it is really really quiet, even with the volume at max on that channel. The mid pot seems to really affect the volume aswell..
Any thoughts?+
PostPosted: Sun Aug 07, 2011 10:50 am
You have to go back to the components, including the pots and check including the wiring. Tubes , voltages etc.
