It is currently Sat Sep 28, 2024 4:32 am
PostPosted: Thu Sep 01, 2005 5:31 pm
Hey folks,
I've noticed a bug on my lightning. When switching from the low input to the high input and vice versa...if there's any volume on the amp at all...
I get sqealing. Any of you guys have any suggestions?
-Frank
PostPosted: Thu Sep 01, 2005 5:32 pm
Just to follow up...the amp is dead quiet when plugged in...no complaints there...
just when the cable is pulled for another input, there's some nasty squealing until it's plugged into the other input..
PostPosted: Thu Sep 01, 2005 11:36 pm
Hi Frank - Did you check to see if one of the switches on the input jacks isnt making contact? I have had it happen on a 5e3 and it made all kinds of crazy noises. Every once in a while something goes wrong thats easy to fix. Joe
PostPosted: Fri Sep 02, 2005 9:43 am
Hey Joe,
I didn't think of that....Obviously, that's an easy check...I'll give it a looksie later on today...
-F
PostPosted: Fri Sep 02, 2005 11:52 am
BTW,
If anyone has any other ideas as well (so I can troubleshoot when the chassis is out)....please let me know.
-Frank
PostPosted: Fri Sep 02, 2005 2:41 pm
My intution tells me faulty input jack(s).
PJM
http://www.diyguitarist.com
PostPosted: Sat Sep 03, 2005 11:00 am
OK guys,
I cracked open the lightnin this morning...the input jacks are wired properly...and the jacks work as intended. I've tripple checked this.
Something else isn't kosher in frank-ville. any other suggestions?
-Frank
PostPosted: Sat Sep 03, 2005 12:42 pm
Frank,
Do you have any pics you can post? Also, do you have both input jacks shorting to ground, or just the hi input? It really sounds like the jacks aren’t grounding right or they are introducing a ground loop with nothing plugged in, did you use Switchcraft or Cliff Style?
Eddie
PostPosted: Sat Sep 03, 2005 1:18 pm
They're Cliff's Erl,
I'll get a picture of the input up as soon as I can...probably sometime in the next hour or so...
-F
PostPosted: Sun Sep 04, 2005 9:13 pm
OK Guys,
I've done some more troubleshooting...unfortuately, my wire stole the digicamera, so it'll be another day or so before I can take a picture of the input section.
The frustrating thing, is that with nothing plugged into the inputs....they *are* grounded. The cliffs are making a connection...and I've verified this visually and electronically.
Any other ideas? I'm at a loss...
-F
PostPosted: Mon Sep 05, 2005 9:29 am
Did resoldering the input jack connections solve it?
PostPosted: Mon Sep 05, 2005 10:50 am
You know it did, Stephen!! :)
Just so everyone else out there can benefit....Richie over at 18watt.com suggested resoldering the input jacks....and that took care of the problem!
-Frank
PostPosted: Mon Sep 05, 2005 11:33 am
Well, if it hadn't I was at a loss, but it's good to know. That's pretty bizzare.
PostPosted: Tue Sep 06, 2005 12:17 pm
I just finished my build last night. I too had a very similar problem. It was also casued by an intermittent ground on the High input. Also using clif jacks....
I reflowed the solder on the ground lug and viola, problem solved. If you haven't already, try to reflow the solder on the ground connections of your input jacks. Visually they may check out, and they may even check out with a meter, but physical stress or changes cause intermittency. I have a feeling that the inner part of the cliff jack lugs may not be fully tinned and may require a bit of additional heat (or good electrical contact on the surface of the lug).
Anyway, post back if you get it (or if you don't)
"A noble spirit embiggens the smallest man..." - Jebediah Springfield
PostPosted: Tue Sep 06, 2005 12:19 pm
Duh, sorry guys, I just realized there was a PAGE 2. Didn't see that, so disregard my post.
PostPosted: Tue Sep 06, 2005 9:03 pm
Good advice & help is always appreciated. Sometiimes you may need to use contact cleaner on those jacks as well, especially if it reocurrs.
Users browsing this forum: Google [Bot] and 10 guests
