It is currently Tue Mar 31, 2026 6:57 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: Deluxe tone mod
PostPosted: Mon Aug 22, 2011 10:58 pm
Ernie R wrote:
After reading this post, and thinking I'd like to go this route in changing the values of the 2 caps to reduce bass response and also that I'm in need of ordering tweed material from Mojotone, and noticing they also carry the needed components....other then them being more money, are there any advantages or disadvantages in going with Vitamin T oil filled Caps ??
also how much Tweed material will I need to cover the cabinet??
Thank you all...Ernie
Oil filled might be a bit smoother sounding . 1 yd should do.
 Post subject: Re: Re:
PostPosted: Mon Aug 22, 2011 11:01 pm
jharasym wrote:
We ship the stock circuit 5E3 design. The options are there and others as mentioned in the Tone Tweaking section of the manual.
Is the manual posted on the site?
Comes with the kit.
PostPosted: Wed Aug 24, 2011 11:06 pm
Thanks Stephen..
PostPosted: Sat Sep 10, 2011 12:21 am
I can only assume he did this after you recieved your kit.
Still it's one thing to read about a mod and it's another to have somebody try it and recommend it. Thanks for that.
PostPosted: Wed Oct 05, 2011 6:27 pm
Hi, I'm wanting to order a couple of extra caps to try out these mods but, at least at Mojo, I cannot get the same spec. The .22 or .047uf works, but only if its 600V rather than the 400V of the original .1uf caps. Keep looking?
thanks
PostPosted: Wed Oct 05, 2011 7:48 pm
thanks
Nope, you're OK with that.
PostPosted: Thu Oct 06, 2011 12:01 pm
Seems odd that such a big difference in voltage wouldn't have an effect, but I'm good with it!
thanks!
PostPosted: Thu Oct 06, 2011 1:47 pm
As long as you don't go under a certain voltage your fine. Something to note though are bigger voltages usually mean bigger size. Maybe get the dimentions before you buy.
