It is currently Thu Oct 23, 2025 8:32 am
PostPosted: Thu Aug 18, 2011 2:22 pm
TC-15 Kit
Plus Mather Head Cabinet
Plus Transformers
Plus MANY MANY MANY Upgrades......
All for = $600 obo
Extras include:
    Transformer Design and Supply (who made the original sampson era transformers for Matchless) http://cgi.ebay.com/Matchless-tube-amp-Power-Transformer-15W-/160393353323?pt=LH_DefaultDomain_0&hash=item255830586b
    including Choke (optional)
    All Tubes: 2x TAD EL84, TAD GZ34, 2xJJ12AX7, EH12AX7
    VRM = Voltage Regulator module
    All upgraded caps & resistors (highest quality available (paper& Oil, beeswax, etc...) including the original that came in the kit.
    Sprague Atom Caps 20UF 500VDC [Found in all high quality amps; See Pics]
    Already mounted most components and wired up for power, but need to finish, and test.
    Mather Cabinet: Pine, and Tung Oiled (to match a tele) [NOTE: needs slight modification since rails come down too far to allow chassis to mount. Refer to pics:]
Pics found here: https://picasaweb.google.com/tyejones/Selling?authuser=0&feat=directlink
Why am I selling? = I started it, got excited, had kids, now we are moving, need the space and money.
PostPosted: Sat Aug 20, 2011 9:19 am
Can you provide some more detail on what remains to be done electronically. I see the cab mod that's needed. is the voltage modulator wired in? etc?
thanks.
gtrpaul
PostPosted: Tue Aug 23, 2011 10:59 pm
Sorry for the late reply, I have been working too much.
I laid everything out in it's proper place (substituted high-end caps & resisters) and ran heater wires to each tube.
The only thing I have soldered is the following: Impedance selector switch, on/off switch, fuse, power jack, rectifier, around 3 caps, and speaker outputs.
I hope that helps. let me know if you have any more questions.
PostPosted: Thu Aug 25, 2011 12:22 pm
I'm interested in taking this amp off your hands and finishing the build...how do I reach you directly - I don't see a way to send you a private message or email. New to the forum...was planning on building an amp.
Jim
daacrusher2001@yahoo.com
PostPosted: Thu Sep 08, 2011 10:13 pm
If it's still available shoot me a line at cmguitar2008@yahoo.com
