It is currently Sat Jan 31, 2026 12:43 pm
PostPosted: Tue Oct 04, 2011 5:42 pm
Hi, I finished building my amp on friday and i've been playing through the amp for a few days now without a problem. Today its started to cause the speaker to pop loudly whenever standby is switched on & there's a big drop in volume. I took a few measurements and here's what I got.
B+ 355v
Plates: V1=127v; V2=171v(pin1), 274V(pin6); V3=178v(pins1&6); V4&5=371v;
Cathodes V1=1.3v; V2=1.2V(pin3), 171v(pin8); V3=120v(pins3&8); V4&5=7.5v;
The plate voltages on V3 are much lower than whats indicated on the layout & the cathode voltages are considerably higher.
I've tried swapping the tube with no change.
I think I may have a capacitor problem here but I'm not sure, any help would be great
All valves are in place, guitar plugged in but producing weak sound when measurements were taken.
Measured capacitance of 22uF 450V caps all measure between 24uF & 27uF. DC resistance in the megaohms.
PostPosted: Tue Oct 04, 2011 9:29 pm
Both channels not sounding correct?
PostPosted: Wed Oct 05, 2011 4:10 am
At full volume on channel2
it's about tv volume. Channel1 is louder
But not by much
PostPosted: Wed Oct 05, 2011 1:56 pm
Were the PI values close to spec before? Now: V3=178v(pins1&6) (250 spec) ; V3=120v(pins3&8) (70 spec);
Measure all Resistor values again and touch up ground connection as well. Touch up the pin solder joints as well.
PostPosted: Wed Oct 05, 2011 2:23 pm
Problem solved :happydance:
Removed board and found a tiny piece of fine wire underneath about where the plate resistors for V3 would have been.
It was an off cut probably from the shielded cable I used for the input wiring. Used compressed air to blow out the chassis of the amp in case I'd missed anything else. Sounding sweet again! Plate voltages back up at 252 & 247 V.
I should have been more careful during the cleanup!
Thanks for your help & for a fantastic amp!
PostPosted: Wed Oct 05, 2011 3:27 pm
Excellent!! nothing like a Post-Build chassis cleaning. I use a air gun / compressor.
Post-Build chassis cleaning. Good advice for all.
PostPosted: Thu Oct 06, 2011 2:18 pm
I just had the same problem with the VRM install regarding wire strands causing some trouble. Some small wire strand poked a hole through the sila pad. Removed wire cleaned everything, tested all values and everything was in line. and she sounds fantastic!
