It is currently Wed Dec 03, 2025 10:08 pm
 Post subject: Finshed tweed pin test
PostPosted: Thu Sep 13, 2012 2:13 pm
Here's a clip
DC junior > amp > sm57 >steinberg CI2 > Cubase > nothing added mixed down mp3
in Bright pinned vol and tone, norm rolled back till its maxed volume
Yeah i gotta stop building and start playing more
http://soundclick.com/share.cfm?id=11888492
PostPosted: Thu Sep 13, 2012 5:54 pm
Nicely done. Thanks for sharing that. Any mods at all? & what speaker were you using?
PostPosted: Thu Sep 13, 2012 10:27 pm
Just the 470k smothing res. Speaker was v30 (only thing I hade avail)
What about the low watt tubbys we talked around. With a little dope.
PostPosted: Wed Oct 17, 2012 2:34 pm
Turns out there was a mod I did not no I did. Thought I had a clear top rca 12ax7 in v2 but it was a clear top 12au7 :oops:
With the 12ax7 in there its way more Neil Young ragget but hey I like it both ways so I'll hang on to the 12au7 when I need a kinder gentler machine gun hand
:happydance:
I have since chanded the coupler cap on the normal chan to .022 and to me its the first time in my life I've had a good clean sound on my bridge pickup. So Thnx for that. As for the bright side I'm leaving it alone as I like the NY edge
PostPosted: Wed Oct 17, 2012 3:24 pm
:happydance:
I see what you did there :D
PostPosted: Fri Oct 19, 2012 12:33 pm
Ok I've killed the rectifier in this amp 2 (insert your favorite reck'em damm near killed him joke) but I had a sovtek back up. All I can say is with 6V6's I really did not like the sound change compared to what I had with the lower voltage from the jj's . Since I did already put in the 10 watt cathode resistor in it. It was time to try out some 6L6's I just borrowed from another amp. To me I like the 6L6 with the sovtek 5Y3. They actually seem louder but I would think that was from the voltage increase. As well as little more open. When I get another JJ I will try it with the 6L6's. At this point I'm thinking the transformers can take it as nothing is running really hot, or I haven't let the smoke out of any components yet.
So my question after all that is should I add screen resistors for this config?
PostPosted: Fri Oct 19, 2012 1:05 pm
I forgot about this. Here's a clip of the original set up with the 12au7 :oops: in V2. recorded with LP mostly on the neck pick up . With a just cracked bridge volume control for the quiet parts (that didn't come out right ) at the beginning and end. (Its with some garage band loops)
http://soundclick.com/share.cfm?id=11953338
PostPosted: Fri Oct 19, 2012 10:37 pm
The OT is higher rated than the original OT but, there is no guarantee running a higher current through it, so experiment but be aware of that. I would be concerned running it full blast for hours with a 6L6 pair.
