It is currently Tue Jul 02, 2024 10:13 am
PostPosted: Tue Nov 13, 2012 7:26 am
Hi,
I want to make a dual footswitch to toggle my tubes and the boost in my amp.
I just bought two DPDT relay kit's on the internet to make this work.
My concern is that when I toggle the hand switch the amp does a pop, that I would like to control, in order to have (at least) the boost switch working in the middle of playing a music.
So if you could suggest any alteration to make this work, it would be great.
The relay kit is this one, please remove this link if it is inappropriate
http://www.muzique.com/schem/dpdt.htm
João
PostPosted: Tue Nov 13, 2012 11:03 am
See viewtopic.php?f=7&t=3312 for some ideas/suggestions for to prevent the boost from popping.
Switching the tubes should not cause a pop.
I haven't tried the AMZ relay boards but Jack the maker/designer is a well respected electronics pedal guy.
PostPosted: Tue Nov 13, 2012 7:31 pm
Thank you for your quick reply Kurtlives.
I guess I am fairly new at this so I ask you to help me out. (i removed the layout, it was too big)
has I am going to use the relay dpdt I got, can you point out or describe in the layout were I should place the resistor, and how to connect it with the present switch.
I can then transcribe this to my pcb relay board has it has the same 6 connections...
I do know electronics, I build LEGO :D
João
PostPosted: Thu Nov 15, 2012 7:21 am
Has I was trying to find how to make this work, I stumbled on a thread about soft foot switch on resources.
Stephen, shows how to make the tubes and boost operate with a footswitch. I am thinking about doing it his way, has he already schooled me on how to build the amp.
I have a couple of questions about his build, maybe someone can clarify me about this.
- the power comes from the white cable in the layout that goes to pin 5 of the rectifier tube, I should divide it before it goes there?
- can R42 de a 27R 1W resistor?
- can I use a relay like «Finder 30.22S 5V» it has 5vdc; 2A; 125R coil resistance and 40mA like the sun hold
- the boost board already has the 22uf cap and the 2k7 resistor, so I should remove from my board these two and the dpdt toggle switch right? ( I already have a boost on my turret board)
Hope you can help me with this,
João
PostPosted: Thu Nov 22, 2012 6:49 pm
Soft Boost Posting here: viewtopic.php?f=12&t=1093
The soft boost does stop the popping because it turn on and off slower than a relay.
PostPosted: Fri Nov 23, 2012 8:34 am
Many thanks coco, I will get on this!!
PostPosted: Fri Nov 23, 2012 10:11 am
- the power comes from the white cable in the layout that goes to pin 5 of the rectifier tube, I should divide it before it goes there? (poer for this comes from the 6.3V tap, so connect to pin 5 and to pin 4. I have used the other 6.3 tap.
- can R42 de a 27R 1W resistor? - yes
- can I use a relay like «Finder 30.22S 5V» it has 5vdc; 2A; 125R coil resistance and 40mA like the sun hold - yes
- no, not necessary, just tie them to the board in the correct places.
PostPosted: Wed Dec 12, 2012 10:01 pm
I built a sIII v6 a year ago and I would love to do this to my amp too, the problem is I am not good at interpreting schematics. I built my amp entirely from the layout print that came with it. So my question is would somebody be willing to transpose the schematic to a layout. Thanks for any help
Tim
also what is a good effects loop to install in the amp?
PostPosted: Thu Dec 13, 2012 11:49 pm
W can share our layout for this if you would like to see it.
PostPosted: Fri Dec 14, 2012 8:10 am
Ya Stephen that would be great
Tim
PostPosted: Thu Dec 20, 2012 5:44 am
Hi all,
Coco, can I see the layout for the footswitch as well? I already bought all parts needed and planning on doing it next week.
Also bought the parts to upgrade the amp to your second version of v6.
Many thanks,
João
PostPosted: Mon Dec 24, 2012 12:11 am
Sorry, we've been busy shipping for Christmas and haven't finished this off yet.
PostPosted: Sun Apr 14, 2013 1:41 am
Stephen, any chance you can post your layout for the boost? Thanks
PostPosted: Sun Apr 14, 2013 9:07 am
Sorry, I will try to post it here when I do.
PostPosted: Sun Apr 14, 2013 4:25 pm
Thanks Stephen for the layout. Can the switch be used for switching the tubes also in a v6.
PostPosted: Mon Apr 15, 2013 12:13 am
No, that's just for boost. You need a second circuit, and a relay to do the tube switch. We did it with a stereo jack and a dual foot switch.
PostPosted: Mon Apr 15, 2013 1:06 am
So is it the same type of circuit connected somewhere else?
