It is currently Sat Mar 28, 2026 12:49 am
PostPosted: Mon Nov 26, 2012 10:33 pm
hi - I tried searching the board but just seems to be questions about polarity between pre-amp and power amp sections.
i just got a kit, doing the build and the rev. 1.6 layout shows the heater polarity switching between V2 and V3? I've always thought you kept the polarity consistent
any reason for this?
PostPosted: Mon Nov 26, 2012 10:47 pm
I needed some clarification when I did my build. If you check out my "heater wiring" post on page two, you'll see a photo. Just follow that if you like. it worked for me. Good luck. :D
PostPosted: Tue Nov 27, 2012 9:52 am
It doesn't actually matter for 12AX7 if the polarity reverses as they are "hum bucking" but you are right, you shouldn't do it. It's bad practice.
I guess 1.6 is the newest layout rev?
If you follow 1.5 as found in the resource section the polarity is fine
download/file.php?id=730&mode=view
PostPosted: Thu Nov 29, 2012 10:04 am
if anything that looks pretty much identical... EXCEPT for the 12ax7 polarity haha
PostPosted: Thu Nov 29, 2012 7:42 pm
Okay so now I have everything wired up, and went to check the heaters for continuity with the bulb out .. and.. I've got continuity across the two heater wires (green - green... right?). So I disconnected them from the pilot lamp just to make sure I have it right, and I still have continuity across the two green leads.
where can I go from here?
PostPosted: Thu Nov 29, 2012 7:55 pm
resistance between them is 0.002ohm .. continuity to ground. I disconnected centre tap from ground and there's still continuity across it but not to ground
PostPosted: Thu Nov 29, 2012 8:52 pm
Very little resistance in the winding. That is normal.
PostPosted: Thu Nov 29, 2012 11:23 pm
the guide says I couldn't be seeing a short between them though, and I can detect continuity across the two heater secondaries with my multimeter - seems odd?
