It is currently Wed Mar 04, 2026 2:56 pm
 Post subject: Busground
PostPosted: Mon Jan 28, 2013 7:34 pm
In the Trinity kits I see some copper wire for bus ground. In some amp layouts I do not see this.
Here is an example
https://www.dropbox.com/s/5og36yddsy63bsi/SL68.jpg
How is the grounding done in this case?
 Post subject: Re: Busground
PostPosted: Tue Jan 29, 2013 7:14 pm
The "buss" could be on the underside of the board. Also not all layouts use this style of grounding. There are star ground systems and galactic grounds. Some run a buss across the pots, soldering to the pot bodies and grounding to that.
In the picture you can see a ground points at the bottom end of the 2 black electrolytic caps near the left side. I suspect there is a wire joining those 2 points under the board. Then from there probably to a ground lug near the power supply. ..just an example..
PostPosted: Wed Jan 30, 2013 10:58 am
Only on the 18s did we ever do a Buss Bar. We have recently dropped that in favour of the new layout. For Trinity Amps, there is a jumper on the board between the pre amp grounds and another for the power grounds. They go to different grounding locations.
On the amp in the picture, I expect something similar. It looks pretty but it might be tough to service it if the board needs to be lifted !!
PostPosted: Wed Jan 30, 2013 11:34 am
This is a Plexi bei John Suhr BTW ;)
PostPosted: Wed Jan 30, 2013 11:48 am
Interesting does he use SOZO coupling caps or any carbon comps in there? Doesnt look like it.
PostPosted: Wed Jan 30, 2013 3:27 pm
Don't think so. I have his Badger also. I chould check what he uses if you are interested.
PostPosted: Wed Jan 30, 2013 3:56 pm
If you Google tube amp grounding you'll get a ton of material. There is many ways to implement a grounding scheme in an amp, some very well done and some poorly executed. There is no one right way either, every style/scheme has it's pros and cons (as noted here).
Nice looking amp in the pic.
