It is currently Tue Jul 02, 2024 9:37 am
 Post subject: EL84 Hum is V6
PostPosted: Fri Feb 08, 2013 12:17 pm
Hi all I've finally got around to doing some trouble shooting on my V6 build. I have quite a bit of hum coming from my EL84s. I have did a lead dress and checked all the ground points. I have tried 3-4 different sets with no change. I also tried and set of old telefunkins I had around and one red platted quite possible the tube but it caused me to do some bias calculations. I used the BBQ calculation page and came up with some pretty high results like around 14 watts. I am currently running 150ohm cathode resistor with a 220up cap. Increasing the cathode resistor quiets the tubes and I have tried up to a 220ohm. The amp gets quieter with the 220ohm resistor but doesn't sound real good and platte voltage gets up around 380 volts. Listed below are some reading I have taken using the 150ohm resistor.
B+ 353 volts
Screen 352 volts
Platte 362 volts
Cathode 12.48 volts
Anyone have any similar problems with there builds. JGK
JGK
 Post subject: Re: EL84 Hum is V6
PostPosted: Sun Feb 10, 2013 11:32 am
You should be OK with a 150 ohm resistor on the EL84 - I see 125 in the pic which would be hot.
The 6v6 is not noisy?
PostPosted: Sun Feb 10, 2013 12:00 pm
Sorry its an old picture I have replaced the 125 with a 150ohm. I am getting ready to do the mods listed in your updated layout for the 6V6. I also have one of your sIII. Just can't figure out why I have the hum with the el84s. I'll se what happens after I do the conversion. JK
JGK
