It is currently Sat Mar 21, 2026 2:01 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: First Tramp
PostPosted: Mon Apr 29, 2013 2:24 pm
flubbed the control pots. argh.
edit
maybe twice. no signal. try try again!
PostPosted: Mon Apr 29, 2013 2:53 pm
Backwards?
PostPosted: Mon Apr 29, 2013 6:27 pm
I thought they must be backwards..
so I reversed them, but now no signal at all.
so back I go.
as of now:
Image[/URL]
Image[/URL]
PostPosted: Mon Apr 29, 2013 9:27 pm
Got it... had one thing in wrong... gets pretty confusing for this old fart when stuff is that messy.
Everything works fine. Gotta run an errand and then test voltages.
Will come back with results.
Using and old RCA 6L6GC and a Ruby 12AX7 for test tubes.
quiet when gtr is down.
seems very nice.
PostPosted: Mon Apr 29, 2013 9:48 pm
I'm doing a little dance here.
just saying.
PostPosted: Mon Apr 29, 2013 10:46 pm
12ax7
all heaters 6.3
pin
1 206
3 1.8
6 204
8 1.8
I have a 330R cathode couldn't get a reading. may have battery dieing
6L6GC
pin
3 434
4 430
8 61.3
3/8 372
I think that looks pretty good.. comments welcome
PostPosted: Mon Apr 29, 2013 11:04 pm
I found this for voltages
Measured resistance of Cathode resistors (switch in 6L6 position) = 321 Ohms
6L6 pin voltages:
Pin 3 = 393 VDC
Pin 4 = 390 VDC
Pin 8 = 27 VDC
but he's set up for 6V6 and I'm just a 6L6GC
trying to find out what others have..any hot cold bias argument.. etc.
PostPosted: Tue Apr 30, 2013 1:16 am
found the cathode R was bad.. took 2 min or more to get up to 300R
dumped it for a handy 360R
tests immediately so I had a bad R in there.
I didn't test voltages further, because on recheck and rethinking I not only had the
bad R but 417 on P1 12AX7.. leading back to that R again cinched it, on top of the earlier
goofy voltage readings.
What I didn't expect when I checked just to see if it would produce sound was
that I'd spend the next 20 minutes playing it without the needed test.
It sounded soooooo good I got carried away.
Crimeny ZP... what a monster tone machine. Even in the sorry state this one is in right
now.
PostPosted: Tue Apr 30, 2013 12:55 pm
Ok new cathode R in. 330R, actual 326.
B+
399, 398, 393
plate 392
screen 390
cathode 24.8
plate/cathode 367
pre
1, 208
3, 1.5
6, 200
8, 1.6
all heaters 6.4
The 100R dropping R is dropping 1 Watt, so that could be a jumper.
I have some hum now, so I'll start with the lead dress and htr routing for that.
PostPosted: Tue Apr 30, 2013 3:24 pm
gained a volt or two removing the 100R.
No changes in the preamp.
pull out on tude switch.. big electrical noise.
where could that come from? went all over the front end, nothing is different from when
it worked fine.
no volume, it seems-quick test, until bass pot is up.
fat thin works fine. all pots function normally.
I expected some hum but it was quiet when I had the dang thing wrong.
Now I have hum.. that kind of makes me think bad or damaged component.
any hints? I'm going over the front end to see if I can have less wire crossing and maybe some shorter wires.
But it puzzles me that the hum showed up so late.
PostPosted: Tue Apr 30, 2013 10:03 pm
I got it. tiny wires shorting the NFB, big squeal.
Sounds good. still a little bit of hum.
better dress and some shielded wire here and there should do it.
edit
tried several changes but still have hum.
the front end is such a complicated and close mess I may never get rid of the hum.
PostPosted: Wed May 01, 2013 2:50 pm
I found what I did wrong.
I think.
PostPosted: Tue May 07, 2013 3:33 am
I think I'll pull the fat/thin switch.
just to reduce wiring.. and go from there.
I may have to just redo the front end.
hummmm. argh!
