It is currently Fri Jan 23, 2026 5:58 am
 Post subject: Taming bass response
PostPosted: Thu Nov 07, 2013 5:22 pm
Recently finished my TC-15, and I'm super happy with the tone and versatility. With one exception, and that's the bass response. The bass is a bit boomy for me when I'm using humbuckers, especially on the neck pickup. I'm playing through an open back 1x12 with a Celestion G12H30, but I've also run it through a greenback with the same results. What can I do to tighten up the bass response of this amp?
 Post subject: Re: Taming bass response
PostPosted: Sat Nov 09, 2013 10:18 am
I haven't heard that before. Try replacing the power tubes cathode bypass capacitor with one about 1/10 the value. Try a 50 uF. We go from there.
PostPosted: Sat Nov 09, 2013 6:39 pm
How low can I go with that cap? I have a 25uf handy.
PostPosted: Sat Nov 09, 2013 8:42 pm
Go for it. Can't hurt . Need at least 25 volts cap,
PostPosted: Sun Dec 08, 2013 8:37 pm
My combo has one of each of those type of speakers in. I have the ability to run each speaker by itself and noticed that I prefered running them both at same time in parallel and bass response was one main reason.
Of course I had to know why the difference so I went researching and found this link which quenched my curiosity. It doesn't really solve anything but the info was helpful to me at least. There is also a link to a BBQ Q&A that explained things a bit too.
http://pickroar.com/378/wiring-a-2x12-c ... us-series/
PostPosted: Sun Dec 08, 2013 10:23 pm
Series parallel switching Works on a 212 with two 8 ohm speakers but not very well with two 16s . Damping would be the main factor I think.
PostPosted: Tue Dec 10, 2013 2:58 am
Just to follow up, I replaced the bias cap with a 50uF and it tightened up the bass nicely. Also dropped the bright cap on the normal channel down to a 100pF. The combination of the two gave me a little more usable range out of the tone controls.
I also changed the speaker to a Celestion alnico gold, which was a very nice (albeit expensive) step up from the G12H30.
PostPosted: Tue Dec 10, 2013 11:46 pm
Thanks for the follow up!
