It is currently Tue Aug 04, 2026 10:23 am
PostPosted: Fri Apr 11, 2014 11:31 am
I built the Plexi...it sounds awesome cranked (especially with the VRM taming my ears!)
I've never played a SL...what are the tonal differences? a little more gain and 'fatness'?
can the Plexi be easily modded to sound like a Super Lead?
PostPosted: Sat Apr 12, 2014 11:47 pm
You can turn it into a Mk. II iF you follow our layout. Clips by unimind if you search for them. Think EVH!
PostPosted: Fri Apr 18, 2014 5:30 pm
I have played a 50W SL years ago. I think the MK II comes close to replicating the tone of a SL but the feel and dynamics are not there. I say “comes close” but I think what is missing can only come from the larger EL34 tubes and their operating characteristics. I felt the EL84s saturate too much when driven by the SL spec in the preamp and I was never able to bring that under control. I have 6CM6s in my amp and they come even closer tonally and even help to give some of the feel and dynamics. In the end I feel that I have come really really close to getting the sound of a super lead in an 18 watt amp and I am very satisfied, but it’s still just not the same as 50/100 watt SL.
Les
PostPosted: Fri Apr 18, 2014 8:24 pm
Unimind wrote:
I have played a 50W SL years ago. I think the MK II comes close to replicating the tone of a SL but the feel and dynamics are not there. I say “comes close” but I think what is missing can only come from the larger EL34 tubes and their operating characteristics. I felt the EL84s saturate too much when driven by the SL spec in the preamp and I was never able to bring that under control. I have 6CM7s in my amp and they come even closer tonally and even help to give some of the feel and dynamics. In the end I feel that I have come really really close to getting the sound of a super lead in an 18 watt amp and I am very satisfied, but it’s still just not the same as 50/100 watt SL.
PostPosted: Wed Apr 23, 2014 9:04 pm
Coco was that your way of saying "yeah, what he said" ? :D
Probably the closest clip I have of replicating the tone AND feel of the SL:
http://soundclick.com/share.cfm?id=11882168
Les
PostPosted: Fri Apr 25, 2014 8:04 am
Yeah, that was my way of mis-posting! You mean you have 6CM6 in your amp tho I think!
Should edit that post if I am correct!
PostPosted: Fri Apr 25, 2014 5:00 pm
Oops. You are correct. I have 6CM6s in my amp. Been so long I forgot exactly what they were.
Les
PostPosted: Fri Apr 25, 2014 10:22 pm
I have been looking at using those tubes agin!
Users browsing this forum: Baidu [Spider] and 26 guests
