It is currently Wed Mar 04, 2026 2:59 pm
PostPosted: Mon Nov 24, 2014 10:28 pm
Hi, I'm new to this, building a tmb and reached the stage where I've installed the rectifier (only) and checking for B+. I'm reading 445VDC for B+ but the schematic tells me it should be 350VDC.. All my plate volatges are in the 440VDC range. Is my rectifier working properly? Is there a way to check if the rectifier is working correctly?
PostPosted: Mon Nov 24, 2014 11:11 pm
Once all the other tubes are in and a speaker is connected the B+ will drop.
What you are seeing is normal
PostPosted: Tue Nov 25, 2014 12:34 am
:thumbsup:
PostPosted: Tue Nov 25, 2014 9:57 pm
Thanks for the quick response. Installed all tubes and speaker, getting better results.
