It is currently Sun Jun 29, 2025 2:54 pm
 Post subject: amp inputs
PostPosted: Thu Jan 15, 2015 12:01 pm
is this generally correct for these amps?
A "low input" usually is a padded input, while the "high input" is actually the stock circuitry. As for their use, it depends what you want from your amp; more gain, use the high side, more headroom, the low side.
when would you use either?
 Post subject: Re: amp inputs
PostPosted: Thu Jan 15, 2015 4:00 pm
Yes... There is a cool diagram somewhere, but the switching jacks change a resistor network on the inputs.
Well it depends. For me I use the low input when I want it sounding cleaner, the hi more dirty. If you had a low output guitar, you might prefer the hi input to give you the best tonal options. Conversely, if you are overloading the preamp and don't like the sound, try the low input. All up to you
Corey
PostPosted: Thu Jan 15, 2015 5:31 pm
Both inputs are stock inputs really. Not sure what that quote was trying to get at with saying that.
The High input is your guitar signal going right to the first gain stage.
The Low input is your guitar signal being attenuated by 3dB through a resistive signal attenuator then going to the first gain stage.
The names explain the gain, volume of both inputs....
PostPosted: Fri Jan 16, 2015 10:00 am
If you want, I can dog up a good explanation
PostPosted: Sat Jan 17, 2015 9:11 pm
I didn't really understand it either until I found this...
PostPosted: Mon Jan 19, 2015 10:15 am
Something I will add to the manual!!
PostPosted: Sun Jan 25, 2015 11:28 pm
Nice find dtp! That's the one I was thinking of, seen it before couldn't remember where :)
Corey
PostPosted: Thu Jan 29, 2015 11:48 pm
Yes, makes it very clear.
