It is currently Thu Jan 29, 2026 6:38 am
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
PostPosted: Wed Jul 27, 2005 11:03 am
does anyone have some nice plans or know where I can find (purchase) some nice layout/blue print(ish) plans for combo and head cabinets?
I'm interested in building a combo amp first based on the sweet sounding TMB sIII. Probably with a single 8 ohm greenback.
Any links or ideas would be appreciated. I'm still in the data collection phase, part sourcing phase. Maybe if we get some good info dear Stephen can make a sticky for here :)
"See, in my line of work you got to keep repeating things over and over and over again for the truth to sink in, to kind of catapult the propaganda." —George W. Bush, Greece, N.Y., May 24, 2005
PostPosted: Wed Jul 27, 2005 5:13 pm
Hmmm I actually found some stuff on the 18 Watt page...
http://www.18watt.com/modules.php?name=Downloads&d_op=viewdownload&cid=35
PostPosted: Wed Aug 10, 2005 6:11 am
I can post plans for cabs if you have found some good ones that work. I have various sets of plans for cabs I build, but I posted only the Lightning ones.
PostPosted: Thu Nov 10, 2005 12:31 am
The 18 Watt site has the combo plan, anyone have or located plans for the Head design
PostPosted: Thu Nov 10, 2005 9:29 am
I'll post some 'marked up' pics for you to use.
Meantime, if you want a small box head to fit the sIII, it's 24" X 8" x8" . You can even make it 22" wide if you want. Cut outs, front & rear - 16-1/2" X 2.25"
PostPosted: Thu Nov 10, 2005 6:10 pm
Here's the sIII head cabinet design, as a guideline and in rough format.
 Post subject: sIII chassis size
PostPosted: Mon Nov 28, 2005 2:22 am
The head cabinet images are great help, thanks.
Just for the record what are the dimensions of the sIII head chassis WxDxH.
I am still waiting for mine to arrive, but I am about to start building the box and want to be sure of the sizing. I will be using 3/4" ply for the outer sides.
Cheers
PostPosted: Mon Nov 28, 2005 2:18 pm
Rowbo:
Chassis Dimesnsions are: 20" W X 6.5" D X 2.5" H
or approx 510 X 165 X 65 +- 1 mm
PostPosted: Tue Nov 29, 2005 6:07 pm
Thanks Stephen,
Just confirming the depth measurement of 6 5/8" on the image, is the distance between the back of the Front panel and the back of the Back panel.
Therefore the 6 5/8" depth includes 6 1/2" for the chassis plus 1/8" to allow for the front and back face plates.
Cheers Rob.
PostPosted: Tue Nov 29, 2005 7:43 pm
rowbo wrote:
Thanks Stephen,
Cheers Rob.
Yes, the dimension is correct, 6-5/8" between the two panels.
PostPosted: Sun Dec 11, 2005 1:10 pm
Stephen,
I don't know if it's listed on the above diagram...but what thickness plywood is apropriate for the head cabinet?
also, what roundover bit is used for the cabinet and where?
-F
PostPosted: Sun Dec 11, 2005 2:06 pm
It's missing:
:arrow: 1/2" thick Baltic Birch plywood.
:arrow: 3/8" Radius roundover.
:idea: I use a Roman Ogee on the front edges to give it a bit more of a radius look.
PostPosted: Sun Dec 11, 2005 2:18 pm
It's missing:
Half inch? Thats it? hmm...
I've been using 3/4 on all my other various head cabs...I guess that makes sense, it looks a bit less 'thick'...
As far as the roundover goes....from what I can see from pictures of the 18watt head cabinets, the back corners of the cabinet are *not* rounded over, but the front and sides are....correct?
-F
PostPosted: Sun Dec 11, 2005 10:31 pm
Correct. Dont round over the rear. I use 3/4" on Matchless style cabs.
PostPosted: Sun Dec 11, 2005 11:11 pm
Right, I used 3/4" on mine as well...and the other amp...
But it makes sense that the marshall cab calls for a thinner ply....since it looks thinner in the pictures...
-F
PostPosted: Wed Jan 04, 2006 4:58 pm
Hey Stephen (or others),
I'm about to start rounding over my head cab....and I was wondering....do the openings on the front and back panels get rounded over with the 3/8" roundover as well?
-F
PostPosted: Wed Jan 04, 2006 5:16 pm
I round them over with 3/8" radius on the 18s; square on the 15s
PostPosted: Sun Jan 08, 2006 2:59 pm
Well, I've had good luck with wood stock in the past. However, the wood I used to build my sIII cabinet is a little suspect...either that, or I had the variable transformer for my router set too low.
I ended up with alot of tearing when I rounded over the head cabinet...so I've had to make some repairs with the aid of wood filler...
Good thing I'm covering this thing with tolex! :)
-Frank
PostPosted: Sun Jan 08, 2006 3:46 pm
It's really hard to not chip especially the finger joints in the corners. A little filler here & there is expected. Tolex will take care of any flaws!
PostPosted: Sun Jan 08, 2006 3:54 pm
Yeah, especially since we're working with ply, which I supose, would chip more than hardwood. Regardless, the cab is already filled and drying...nothing some sandpaper can't fix now...
Regardless, the 3/8" roundover looks good. I had run out and gotten myself a bit, since all I had here was a 1/2". Even though the difference is 1/8", the 1/2" bit would have looked stupid here....probably wouldn't have even worked with the 1/2" ply.
