It is currently Wed Apr 09, 2025 1:44 pm
 Post subject: EF 86 channel
PostPosted: Fri May 08, 2015 10:56 am
Can an EF 86 channel be added with different tone? Blank opening available in chassis
 Post subject: Re: EF 86 channel
PostPosted: Sat May 09, 2015 7:36 am
Yes. Already incorporated in the TC15 but there is an extra hole for a tube in the 18 watt chassis as well.
PostPosted: Sat May 09, 2015 8:35 am
Yes, What I wanted to know was could'nt another E 86 channel be added that is modeled differently, Different tone ect. I own TC 15.
PostPosted: Sat May 09, 2015 3:44 pm
there is an extra socket hole that if planned accordingly, you could . Or you coulr remove the non EF86 channel tubes and go from there. Its all possible, depends how far you want to go with it.
PostPosted: Sat May 09, 2015 4:31 pm
Do you have any ideas about adding an EF 86 stage to current amp?
PostPosted: Sat May 09, 2015 4:33 pm
I am willing to spend some to get different tones. As you probably guessed I am not amp tech but I am learning by doing
PostPosted: Sat May 09, 2015 10:58 pm
The EF86 is pretty good already. I would suggest a Matchless Clubman configuration with a 12AX7 followed by an EF86 then into the PI.a
PostPosted: Sun May 10, 2015 7:24 pm
Have the schematic of clubman and understand except PIa
PostPosted: Mon May 11, 2015 5:36 pm
Typo - just PI = Phase Inverter
