It is currently Mon Aug 17, 2026 5:53 am
 Post subject: Plexi MkII clips?
PostPosted: Fri May 22, 2015 3:49 pm
anyone got some?
interested in hearing the normal channel...might rewire my MkI into one, if i like the sound...
 Post subject: Re: Plexi MkII clips?
PostPosted: Fri May 22, 2015 8:21 pm
Have you given up on trying to fix your amp?
PostPosted: Sat May 23, 2015 2:54 pm
not yet..I honestly haven't had time to touch it...
I figured that if the MkII normal channel is more 70's SL then while I had the board out re soldering everything, I would alter the MkI normal channel
only the one resistor I noted was out of spec but it shouldn't throw the voltages way out...
before I do change I would like to hear what it sounds like...
PostPosted: Mon May 25, 2015 8:47 am
Clips were TMB channel I believe. It has some bite, if thats what you want and You can change it without pulling the board.
PostPosted: Mon May 25, 2015 11:56 am
I STRONGLY suggest you get it working as-built before you try doing any mods.
Have you considered taking it to a tech to get it working? Maybe one who is willing to let you look over their shoulder while they are troubleshooting it?
PostPosted: Tue May 26, 2015 5:10 pm
I have had mine with the original 220uf then a 2.2uf and now a 25uf
With a small cap it does sound not as woofie fully cranked but the drawback is when you turn it down it becomes less fat . At this point I'm going for a 2.2 and a 25 on a switch.
As for fixing you amp I'm down in the Trenton area a lot . Would be willing to help you out.
PostPosted: Wed May 27, 2015 6:36 am
:thumbsup: :thumbsup: :thumbsup:
PostPosted: Wed May 27, 2015 12:10 pm
Thanks for the help guys...i appreciate it!
