It is currently Wed Dec 03, 2025 6:38 pm
PostPosted: Sun Oct 25, 2015 7:45 am
If I am only going to use 8ohm do I simply cut the green wire from the output transform off and put some shrink tubing over it. I can't see the green wire being used in any images on the forum.
thank you!
PostPosted: Sun Oct 25, 2015 12:43 pm
If you aren't going to use the green wire, yes, just cap it with heat shrink tubing and coil it up. I wouldn't cut it. You might want to use it later.
The secondary of the output transformer that came with my kit doesn't have a green wire. Only a yellow one for 8 ohms and black one for ground.
PostPosted: Fri Nov 13, 2015 10:59 am
New tweeds have 4 and 8 ohm taps! Same OT design, extra tap added.
