It is currently Tue Jan 20, 2026 11:43 am
PostPosted: Sun Dec 27, 2015 11:31 am
Hi folks!
Can anyone tell what are the combo cabinet dimensions for TC-15?
Your opinion on 1x12, 2x12 or 2x10 configuration?
Wich one do love and use?
Can the 1x12 cabinet size option be used for 2x10 configuration?
Thank you.
PostPosted: Mon Dec 28, 2015 9:36 am
Anyone? :-(
PostPosted: Mon Dec 28, 2015 5:14 pm
TC-15 usually comes as a head. There are combos (not the norm), from what I remember they are 1x12.
Email Trinity for dimensions.
PostPosted: Mon Dec 28, 2015 6:03 pm
In a TC15, a 210 combo is great. Otherwise 112. They are about 24x20x10.5 size.
PostPosted: Tue Dec 29, 2015 4:56 am
Can the 1x12 combo cabinet be used to insert 2x10 diagnonaly?
Any opinions on 1x12 vs 2x10 combo configuration?
PostPosted: Tue Dec 29, 2015 2:40 pm
Combo cabs are not recommended with EF86 tubes. They can have a much shorter lifespan in a combo because they tend to go microphonic more easily than most other tubes.
2x10 will be less "directional" than a 2x12 or 1x12. That is, the listening "sweet spot" is actually wider with a 10" speaker. Counter-intuitive I know, but true.
Volume wise, about on-par with a 1x12, in general. Of course there are other factors here like speaker efficiency, cabinet design, etc.
PostPosted: Wed Dec 30, 2015 8:23 pm
For the same efficienct speaker, more volume (+3db), more bass, better sound dispersion, tighter bass, strong mids and highs.
24" wide cab will fit them side by side.
Try a JJ EF806.Might not be so susceptible to microphonics.
PostPosted: Sun Jan 03, 2016 2:19 pm
You re talking aboth 2x10 combo?
