It is currently Mon Aug 25, 2025 5:37 pm
 Post subject: "Vox" clone EF86 channel
PostPosted: Tue Feb 16, 2016 4:18 pm
I'm posting these clips here because of the great help I received on this forum while building a modified "Foxy 18" by BrownNote. The thread for this can be found here:
http://trinityamps.com/phpbb/viewtopic.php?f=2&t=4194
https://soundcloud.com/pharmrock/vox-ef ... l-examples
the amp has an EF86 in V1 (NOS NEC), 12AX7 (EH) and 2 EL84's (Gold Lion), and EZ81. ClassicTone transformers.
Gain (8)
Tone (7)
Contour (6 position rotary...I used positions 1, 2 and 3)
H-Cut (aroudn 1 to 3)
Volume (8)
Parts strat with JbJr in bridge, Duckbucker middle, Alnico II Pro neck. Amp settings as above with occasional adjustments on Contour and Hi-Cut. Everything else with guitar volume, tone and pickup selector. JBJr is split in the middle/bridge position.
Closed-back 1x12 WGS Green Beret->SM57->Presonus 22VSL->Garageband. Left channel has very slight reverb, otherwise no effects.
PostPosted: Wed Feb 17, 2016 12:08 pm
Sounds great. This is probably pretty close to what our EF86 channel would sound like.
PostPosted: Wed Feb 17, 2016 10:10 pm
Thanks!...just some noodling and trying to show how it really cleans up with the guitar volume.
I'm debating on a TC-15 as the next project, but am also thinking about a deluxe since I already have this EF86 based amp.
PostPosted: Wed Feb 17, 2016 10:18 pm
I should also mention I am very tempted to drop the Trinity transformers in this amp, hearing how big of a difference it made in my superlite.
PostPosted: Wed Feb 17, 2016 10:30 pm
Yes, a Tweed would be a good next amp.
PostPosted: Thu Feb 18, 2016 8:14 pm
Sounds great PharmRock! Great tone and playing.
I'm a big WGS fan. This makes me think I should try out the WGS Green Beret for my TC15...
PostPosted: Thu Feb 18, 2016 9:29 pm
That project turned out really well, sounds great.
PostPosted: Fri Feb 19, 2016 2:01 pm
I've been really happy with all the WGS speakers I've tried...ET-65, Green Beret, Veteran 30. I haven't tried any of their "American" voiced speakers however so can't comment on those.
Kurtlives...the background hum/noise of the amp is virtually non-existent, even when cranked. The shielded cable and wire routing tips really made a difference.
PostPosted: Mon Jul 23, 2018 5:31 am
SPAM!!
