It is currently Thu Jan 22, 2026 1:21 pm
 Post subject: Power supply test 240V
PostPosted: Sat Feb 27, 2016 3:51 am
Just wired up transformer, but when running the test I'm getting 640v not 580v on the rectifier socket. All other voltages are correct.
PostPosted: Sat Feb 27, 2016 9:20 am
It will go down when you attach the rest of the circuit.
Maybe your wall voltage is a bit higher than 240V.
PostPosted: Thu Mar 03, 2016 10:09 am
Voltages are loaded voltages, not unloaded. See with tubes installed
PostPosted: Sat Mar 12, 2016 2:56 am
Amp is finished, but still reading 640v across rectifier and B+ is 370V. Amp sounds quite brash and muddy when turned up but can't say I've got that far as its so loud!!! Would the higher readings have an affect on this?
PostPosted: Sat Mar 12, 2016 10:50 am
Probably something else
Post some pictures
PostPosted: Sun Mar 13, 2016 2:38 am
Wiring is per instructions for 240v. Wire for on/off switch left a bit long as VRM is yet to be installed.
