It is currently Tue Dec 02, 2025 8:30 pm
PostPosted: Thu Jun 02, 2016 11:11 pm
Better create another topic for this:
After I installed the VRM (scaling the whole amp), I noticed the following, that I had not before.
I noticed an awful cracking sound in both channels.. but that happens only when I put the treble pot between 0-3 or 6-10.. And even with the VRM at 10.
If I put it in the middle it sounds OK!!
Planned to disconnect the VRM if that is the cause..
Any ideas? Thanks!
PostPosted: Fri Jun 03, 2016 9:36 am
Never seen that as a result of adding a VRM. Are the/any VRM wires twisted or braided?
Are they close to a control pot?
Do you have a picture of the installation?
PostPosted: Sat Jun 04, 2016 9:28 am
No, those wires are not near the pot.
Unfortunately I do not have a camera right now.. I will try to move some wires with a wood stick to see if I discover something.
I also do not think this could be caused by the VRM.
It probably have been there before but I had the treble pot in middle position, so I did not notice it..
PostPosted: Sun Jun 05, 2016 8:43 am
If the amp is not in a box, or shielded or close to a flourescent lght, it can also pick up noise.
PostPosted: Sun Jun 05, 2016 6:27 pm
Yesterday I turned it on and did not notice any issue at all!!
I dont know what I could be / had been.
Perhaps some interference with something (dont really think so), perhaps a tube failure.. dont really know.
I will test it more times before touching anything..
Thanks to all!
PostPosted: Sun Jun 05, 2016 7:36 pm
Phantom noise is quite a common problem! :D
PostPosted: Mon Jun 06, 2016 6:49 pm
Could be a loose connection. One the day the connection is good and making contact the next day it is a little intermittent and you hear the crackle.
Sometimes it is actually useful to bang on the top/sides of the amp with your first while it is running to try and see if you can induce the symptoms. Something similar to this: :damntech:
PostPosted: Mon Jun 06, 2016 7:02 pm
Gonna try this. Yesterday I plugged it in another time and again, had no issues..
Users browsing this forum: Google [Bot] and 33 guests
