It is currently Thu Aug 27, 2026 6:31 pm
 Post subject: Tryfly PCB build
PostPosted: Mon Jan 16, 2017 10:50 pm
Building a Trifly as my first tube amp build. I got everything together and powered up but I'm not getting proper voltage at C. B+ is ~280V but after the 22k resistor I'm only getting ~12V. My meter says the resistor is fine though. Should I just replace it even though it reads fine?
EDIT: Figured it out. Bad smoothing cap. What are the chances. Changed it out and all is well.
 Post subject: Re: Tryfly PCB build
PostPosted: Thu Jan 19, 2017 11:34 pm
Bad smoothing cap. Crazy, let us compensate you on that. Email stephen
PostPosted: Sun May 12, 2019 5:24 am
TheDecline wrote:
Building a Trifly as my first tube amp build. I got everything together and powered up but I'm not getting proper voltage at C. B+ is ~280V but after the 22k émotions et sentiments resistor I'm only getting ~12V. My meter says the resistor is fine though. Should I just replace it even though it reads fine?
This is a good article because there are many tips and also many advices that will be very useful to me.
