It is currently Sun Sep 06, 2026 4:05 pm
PostPosted: Fri Jun 20, 2008 7:25 am
Meanwhile back at the plant...
What we use here when we can't clean off the flux is Kester #245 63/37 "No-Clean" solder, a diameter of .031" for our purpose is fine. We're using the 66/3.3% core/flux ratio. If you don't want to clean or can't remove the flux after soldering (moisture sensitive parts like certain swicthes, trimpots, etc.), this stuff is great. If you do intend on removing the flux... DO NOT USE NO-CLEAN SOLDER!!! Long story but basically, don't let managers spec your solder for you :x
For a "Yes-Clean" RMA solder we're using the Kester #285, same diameter, core and flux ratio. I'm showing one pound of either of these for around $11 bucks in my Stanley Supply catalog, catalog #412-885 for the Kester 245, and #183-988 for the 285. www.stanleysupplyservices.com
If you use additional flux for rework, be sure to get the flux that matches the solder you are using. The same place has both rosin flux and No-Clean flux pens for not a lot of money, or in gallons for higher volume production. Hey Jac, don't forget to open a window while soldering!
Joe G
Some assembly required,
Brain sold separately...
PostPosted: Sat Jun 28, 2008 9:37 pm
I like Sn62. Last roll I bought was Kester, 'cause I can't find Ersin Multicore anywhere anymore. But Ersin used to be the crap.
I'll always buy lead-bearing as long as I can get it, you'll have to drag me kicking and screaming to RoHS compliance.
 Post subject: Re: Which solder??
PostPosted: Thu Mar 09, 2017 8:54 pm
This short video will shed light on the whole solder alloy question.
https://youtu.be/ZmCBXvm6C6E
The short of it: Use eutectic solder --> 63Sn/37Pb
PostPosted: Thu Mar 09, 2017 11:05 pm
Thanks for the link. I will check it out and maybe post it in the Resource section.
Love the lead! Sorry ROHS!
PostPosted: Sun Jul 22, 2018 10:03 pm
SPAM!!
Users browsing this forum: Google [Bot] and 4 guests
