This is my first post so bear with me.Ok so I have a VRM I am trying to install in a Vox AC30CC1.as I understand it I am going to put it in place of the power switch right?ok...so I have removed the switch and attached to the power switch are 4 wires.2 of the wires go to the power transformer-red and black.The red wire from the power trannie also has a green thermistor? attached to it.It is labelled SCX 152X.Should I leave it on?with the VRM install?There are red and black wires coming from the 3 prong cord .It has a T4L250V small fuse in it.So which of these 4 wires goes to the top of the 1M VRM pot?Where do the other 2 wires go if not on the VRM?The standby switch has 2 wires attached -one white wire going to the PT,one grey wire going to the HT fuse which is a 250v 500mAL.What do I do with these wires or at least with the grey wire from the fuse?I do have the install guide which is informative but my problem is the amp wiring and making it work with the VRM.I have modded 4 other amps before and installed PT ,etc,but this is a bit difficult for me a bit of advice would help greatly.Thanks.
