It is currently Wed Jul 17, 2024 1:27 am
 Post subject: Its alive
PostPosted: Fri Jan 13, 2006 7:49 pm
Hi all !
Just finish my first amp , It`s a sIII.
I have had much fun building it learned a lot.
Fired it up yesterday and tested it for 10 min super .
Today i got to play it and did some more checking, it hum’s but not to bad
When i have no guitar plugged in and all the vol on max no hum ,it gets
a litle nosy when i plug in the guitar.
It`s mostly white noise
I’m planning in do somme more checking tomorrow .
Planning on swapping the wires from the ot to see if that helps.
I made a voltage chart here it is:
V1: 1-169 3-0.79 6-170 8-0.79
V2 : 1-167 3-1.29 6-261 8-166
V3 : 1-212 2-46.5 3-67.2 6-209 7-46.5 8-67-3
V4 : 3-11.37 7-334 9-323
V5 : 3-11.37 7-328 9-323
V6: 1-287 3-345 7-287
http://www.burningheart.com/_lib/util/s ... =2517&s=hi
PostPosted: Sat Jan 14, 2006 1:03 pm
Malt, Congratulations.
If the amp doesn't hum when you have nothing plugged in:
a) you have wired the input jacks correctly
b) that's the true amount of hum in the build.
If the amp only really hums when you have a guitar or cable plugged in:
a) that's the true amount of hum in the guitar/cables
b) there is not much you can do about it, especially Single coils.
Reversing the transformer wires wont reduce hum and MIGHT actually induce squeal. It looks like you've built it correctly. The White noise is from the carbon comp resistors. How does it sound??
Here's some voltages to compare to:
AC Mains Voltage 123 VAC; B+ 440 VDC no tubes installed
V1 - 12AX7 ; Pin Volts ;1 154 ;3 1.0 ;6 160 ;8 1.0
V2 - 12AX7 ;Pin Volts ;1 184 ;3 1.6 ;6 278 ;8 184
V3 (PI) - 12AX7 ; Pin Volts ; 1 222 ;2 55 ;3 80 ;6 217;7 54 ;8 80
V4 - EL84 ; Pin Volts ;3 11.7 ;7 364 ;9 354
V5 - EL84 ; Pin Volts ; 3 11.7 ;7 366 ;9 354
PostPosted: Sat Jan 14, 2006 5:27 pm
Stephen thanks fore the kit very nice.
I will check the voltage ones more .
The first pre amp tube are a litle microphonic + some of the wires from the
first tube socket. At the moment i have some old tubes in, i will put some new tubes in and check again.
I played it true a Marshall 4x12 whit green backs very loud.
I’m gone try it whit a celestion blue next.
Btw when i measured the amp i had 228-229 volt in .
PostPosted: Sat Feb 04, 2006 9:37 pm
the amp is fine now i grounded the speaker output and that removed the
lo buzz. It`s working super now no noise :P
so i have to say thanks to s2 and coco fore a very nice amp.
Thanks :lol: :lol: :lol:
to bad It`s my brothers amp ahhh gone start new one no .
what’s is gone bee ? sIII fore me!
http://forum.vintagegitar.no/index.php? ... &private=0
:twisted: :twisted:
PostPosted: Sun Feb 05, 2006 11:05 am
malt wrote:
the amp is fine now i grounded the speaker output and that removed the lo buzz. It`s working super now no noise :P
Good news malt. Sounds like grounding that output jack is working for you as well. Wher edid you ground it to?
PostPosted: Sun Feb 05, 2006 12:12 pm
Where did you ground it to?
I ran i litle wire between the output jack and chassis for now .
Gone make a new ground wire and ground it the same place as the cap can.
 Post subject: Re: Its alive
PostPosted: Fri Dec 24, 2010 12:26 am
well the ground for the output jack is still in th same place hehe, and the amp is still going strong ! Had the amp open to install a vvr so i had to take a picture, nice to se that a home made amp last longer than a BS production amp :twisted:
BTW Merry Christmas from NOrWAY :lol:
PostPosted: Fri Dec 24, 2010 4:07 pm
Nice build. Love that Cradle too!! Merry Christmas from Canada!!
