It is currently Sat Mar 28, 2026 12:46 pm
PostPosted: Tue Jan 24, 2006 11:17 am
Hey Stephen and gang,
I notice the bass pot in the sIII schematic was changed from 1meg to 500k.
What effect did this have on the channel, with respect to how the bass pot works?
I must've worked off of an order copy, as mine is 1meg...
-Frank
PostPosted: Tue Jan 24, 2006 7:56 pm
Yeah, I changed it to give more control of the Bass. It seems to be just a bit better. For $2 you can try it out too.
PostPosted: Tue Jan 24, 2006 9:17 pm
I tried both and prefer the 500K myself
Nigel
PostPosted: Wed Jan 25, 2006 10:57 am
I might just be able to chuck a 1m resistor on the pot (instead of ordering a 500K).
Normally when I knock a 1meg down to 500k, I straddle the first and third lug with the resistor...however, in this case, The 3rd lug isnt used...
I wonder how I could make it work this way....
PostPosted: Wed Jan 25, 2006 4:07 pm
That should still work as it will lower the overall resistance of the pot.
PostPosted: Wed Jan 25, 2006 8:58 pm
Try adding 500K across the wiper to ground. That might change the range just enough.
PostPosted: Wed Jan 25, 2006 9:04 pm
Frank, you are just going to have to double the quantities of everything you buy so you have plenty in the parts bin, you keep kidding yourself that this is your last amp :lol:
PostPosted: Wed Jan 25, 2006 10:03 pm
LOL! Very true!!!!
PostPosted: Thu Jan 26, 2006 7:58 pm
So guys, just out of curiosity (because I would love to just fatten my TMB channel *oh* so slightly), what effect would this pot change have?
Other than that, I'm going to consider changing the coupler from v1 to a .022uf...
-F
PostPosted: Thu Jan 26, 2006 8:31 pm
It would give you a bit more control of the bass, maybe fatten up a bit. If you want to fatten it up, then I'll give you some tips...right out of the manual.
To Fatten Tone on TMB Channel
1. Change C1 to 0.022uF
2. Change C2 to 2.2uF -OR- change R5 to 2.7K -OR- both
3. Change R11 to 33K
4. Change VR5 to 500K-A or 250K-A to give the bass control more useful range
PostPosted: Thu Jan 26, 2006 9:33 pm
For starters I was going to try #1 on your list...since I've got experience with mucking with the preamp coupling caps...so I know what to expect...
-F
PostPosted: Thu Jan 26, 2006 9:40 pm
Report back on your findings please. Maybe you'll want to have a F-A-T-T & skinny switch :P
PostPosted: Thu Jan 26, 2006 9:46 pm
You know, that's a cool idea...although i suspect the .022uf coupling cap would also add some volume, wouldn't you think? resulting in a volume difference between the two settings?
-F
PostPosted: Fri Jan 27, 2006 4:28 pm
OK,
I've made two tweaks:
1) Dropped value of 1mg bass pot to 500k by straddling a 1mg resistor across lugs 1 and 3 of bass pot. Resulting in 500k pot...Very subtle but welcome change to the way the bass knob reacts!
2) Changed coupling cap from .0047uf to .022uf between v1 and v2 of TMB channel. This effectively destroyed the beauty of the TMB channel on the sIII....there was a slight increase in bass....but it also added a raspy, fuzzy distortion that I remembered from my 18watt lite days....I immediately reverted back to the .0047uf cap and the amp is literally perfect now.
This should teach me to make one change at a time! :) I made both changes at the same time and I thankfully backed out the coupling cap first...which returned me to just the sIII with the 500k bass pot.. Perfect!
This coupling cap experience actually raised an important issue that I've been constantly fighting with my lightning deluxe. As most of you know, I've fought a raspy buzzy tone in that amp for months...and I made a whole slew of changes to the preamp to get rid of it...and in some cases, reduced distortion that I otherwise would have wanted from the preamp. After hearing the coupling cap results from the sIII, the resulting sound is *very* similar to what my lightning had done...so I am tempted to revert the lightning's preamp to the amount of gain I want...and see if playing with the coupling caps will fix the problem. (granted the current coupling cap in there is on 500pf, so I can't imagine going any lower! )
I'll report more on that in the lightning forum if the changes render something worthwhile!
-Frank
PostPosted: Fri Jan 27, 2006 7:04 pm
Good feedback. Looks like changing that coupling cap from .0047uf to .022uf between v1 and v2 of TMB channel is not the greatest idea.
Fat & Raspy - :roll:
PostPosted: Fri Jan 27, 2006 7:37 pm
Yeah, it turns the amp from a high school cheerleader into Rosie Odonnell!!! :cry: :cry: :cry: :cry:
PostPosted: Fri Jan 27, 2006 9:39 pm
Does that mean it sounds good after nine Coronas?
Nigel
Users browsing this forum: No registered users and 60 guests
