It is currently Thu Apr 16, 2026 12:40 pm
PostPosted: Sat Apr 13, 2019 10:00 am
Hey There,
I'm looking for advice on how to solder the components to the board. I've soldered components before to a board but there were turrets on that board. The board I have now just has eyelets. I'm assuming that you don't want the components to sit flush on the board to allow for air circulation for cooling. Any advice would be appreciated.
Thanks. :)
PostPosted: Sat Apr 13, 2019 9:45 pm
I've seen it recommended that the high wattage power resistors be (3W, 5W) be mounted proud of the board. Other than that they can be flush with the board, like a PCB board.. Also, you can offset them (power) resistors off the edge if they're located near there.
PostPosted: Sat Apr 13, 2019 10:00 pm
Thanks Kindly Stephen. :D
PostPosted: Sun Apr 14, 2019 7:47 am
:thumbsup:
