Now that I have a solder I like, I got started on the eyelet board. I decided to wire all the jumpers on the front face of the board, rather than the back. I don't want to wind up pulling the board back out of the chassis if I make a wiring error, or if I want to modify the circuit in some way. Putting the infrastructure wiring on the front, where I can get to it, seemed like cheap insurance.
File comment: Starting on the eyelet board
If I were doing this again, I'd consider running the jumpers a little more neatly. I'm not crazy about how they look.
The photo above also shows a little clip-on heatsink. The tip temperature I'm using is about 100F hotter than I would normally use for tin-lead solder. Also, the eyelet joints take quite a bit of dwell time to get up to temperature. This makes me worry about how much heat gets conducted into the components, especially ones with shorter leads, so I used a heat sink on the leads of capacitors and diodes whenever I could fit it.
I wired up the board to match the 3-way bias mod I proposed in @jmczaja's thread about running EL34s (
viewtopic.php?f=16&t=6196). This mod changes resistor values, and substitutes a DPDT on-off-on three position switch to give bias settings for 6L6, EL34, and 6V6. Here's a schematic showing what I did. The tube in this schematic is V2, and the resistors and switch replace R15 and S4.
File comment: 3-way bias mod
This gives three bias resistor settings:
- 760 Ohms when the switch is in the center-off position. This is close to the stock 750 Ohm 6V6 setting.
- 330 Ohms when the switch is set to jumper out the 430 Ohm resistor. This is close to the stock 324 Ohm 6L6 setting (the 324 Ohms comes from putting 750 Ohm and 570 Ohm resistors in parallel).
- 430 Ohms when the switch is set to jumper out the 330 Ohm resistor. This almost exactly matches the EL34 bias mod of swapping in a 1000 Ohm resistor for the 570 Ohm bias resistor (750 Ohms and 1000 Ohms in parallel come out to 429 Ohms).
I used 10 Watt power resistors for the new bias circuit (vs. the stock 5 Watt resistors). I don't think this was strictly necessary. Even allowing for the nominal 29V cathode voltage of V2 to be a little high (say, 33V) and the 330 Ohm resistor to be 10% low (297 Ohms), the power dissipated by the resistor is still under 4 Watts in 6L6 mode. OTOH, I don't want the neighboring electrolytic caps to get too hot, and the larger size of the 10W resistors spreads the heat dissipation out, so it seemed like a good call.
File comment: Installing the updated bias resistors
Here's a crudely edited layout picture showing how I'm wiring the mod.
File comment: Only minor changes to the wiring.
This isn't tested yet. When I finish the amp, I'll post bias currents, power dissipation, etc.
I'm open to any comments or suggestions if you see issues with this mod!
