It is currently Thu Apr 16, 2026 12:33 pm
PostPosted: Wed Mar 03, 2021 11:54 am
I'm thinking of changing out the 5w, 560 k wire wound resistor, to a 5w 1k so I can use bigger tubes in it. The question is, what's the difference in tone if I decide to use the smaller tubes now and then?
PostPosted: Wed Mar 03, 2021 9:16 pm
What tubes are you wanted to change too? You shouldn't need to change any resistor to use a 6L6, EL34, Kt88, etc. Look at the mod for adding the second DPPT switch to support the bigger tubes. If you are after more volume, not just a different tone, look at the above pasted links for the negative feedback loop mod.
